Converting an M to gas from LP
8NKidd
Can anyone tell me what all I'd need (other than the obvious gas tank and line) to convert a LPG M to regular gasoline? Would I have to do something different with the steering system? Thanks!
You will need a M carburetor, air cleaner connections, and the tank/ lines. The steering wheel and support will need to come off if the shaft goes through (probable), to remove the lp tank. Be sure to get gasoline tank support and pads (or check closely to assure they are not different. There were different companies doing the conversions, so some are different. Jim
Dumb question: Were Farmall Ms available with factory LPG or are all LPG Ms aftermarket conversions from gasoline and distillate tractors?
