farmall 300 utility
Lee Tho
I have just purchased a 300 utility and have not located the serial numbers on it can someone tell me where to look? I found the numbers 361 552 R1 and c169 on the right side of engine but don't think this is serial number I would appreciate any help anyone can give me as far as year HP or anything else on this tractor thanks lee
Serial number should be on a plate on the left side near the starter About 2-1/2 X 3-3/4" aluminum.
The C169 is engine Cubic inch displacement (correct for a 300U) TractorData.com is your friend. Jim
Jim, I think you might be wrong this time. The serial number plate on my 300 utility is on the right side near the gas tank and oil filter. You can see the aluminum plate on my attached picture. But I do agree the serial plate would be on the left side near the starter on the 300/400 Farmall models. Al
You are correct, i have been away from My 350 U for 3 years and it is operated by my brothers. Similar place wrong side. jim
