(quoted from post at 05:38:25 02/23/17) Where the suction line is now is off 1/2 inch pipe threads. Should be able to use the same fitting on hose end to fittings. The 1/2 inch suction port is not ideal but several have them plumbed like that. Yes put a plug in the side port. With tractor running in neutral and clutch pedal up, did you try holding the belly pump rod full back and then operating the Christmas tree valve forward and back to see if hitch would raise and lower. If internals and drive to belly pump is intact it should do that. If internals are not intact some of my information will be off. With live pump and that valve you need a relief valve.
(quoted from post at 20:13:13 02/25/17) This may be a stupid question, but are you sure the valve shaft isn't broken?
(quoted from post at 08:01:30 02/27/17) Good to hear!! Funny how some of the most puzzling problems in life end up having such simple fixes.
