farmall 300 dash removal
dewy
removed dash ,,real tight with gear shifter in the way....question is anything special about removing the 3 bolts and pulling gear shift
assembly and reassembling after dash is back in....as long as its in neutral will it just drop back in............thanks dewy
couldnt believe all the trash an build up of packed in black crude behind that dash.towards the floor.........dewy
