notjustair
This question is asked way too soon without all of the information. I want to know anyway! Can a light switch operate but cause blown fuses periodically?
886. I put two additional work lights on it a couple years back. This fall I was fertilizing with it ("field" lights on) and it blew the fuse for the lights. I replaced the fuse and it would run the "road" lights fine without blowing the fuse so I didn't tempt fate and just used those to finish. I looked and thought I found a loose connection where I had added the lights that may have grounded out. I replaced the connector and all was well. This winter I have noticed the switch getting picky about where it had to be for the lights to come on so I kept meaning to pick one up the next time I was at CIH. Two nights ago it blew the fuse with the work lights on again. I replaced it and only used the road lights to chore (with those stupid flashing lights annoying me the whole time). Last night I got in it and could get the flashers to work but no others. If I wiggled it just right I could get the front road lights to flash but not stay on. I was so mad I used another tractor to chore and put the new switch on the RIGHT NOW list. I didn't even check to see if it blew the fuse but I'm doubting it since I could sometimes get them to come on with creative wiggling. I'm in the house for the night or I would go look at that fuse.
Do I have two problems or can a bad switch blow a fuse?
