FARMALL 460 hydraulics
I have a recently purchased a FARMALL 460. The hydraulic pump is under constant pressure, when we move the lever for the fast hitch it tries to free flow like it is suppose to. When the engine is shut off the fast hitch drops all the way down. Any help will be greatly appricated. Thanks in advance, Gary
Just a thought here, but if it has remotes on it, down about boot top high under the dash are the single and double acting valve controls. They are a couple round valves (one for each outlet about the size of a quarter) with a raise flat spot for a wrench.
Play with them and see of the pump acts different.
