Stage 2 Super H hydraulic remote question
Howdy fellows, been awhile and I have a question I want to add a single rear remote on my Stage 2 Super H. It is bone stock original with no christmas tree which is fine I just want power up for IH 37 disk there are 2 lines coming out of the rear of the hydraulic box that end in 1/2 pipe plugs can someone tell me for sure which one is for delayed lift and if I am only going to use one does it matter which one I plumb to? Thanks Rex
Explaining more, the unit has two openings for lift and gravity or other return ways to retract a hydraulic cylinder. When built the two openings were plumbed to tees with two openings each from the tee. Lines going to the lower and upper openings at the unit near starter have a different release check to hold oil pressure from returning to unit until opened by pushing operating lever forward. But for your use whatever opening you use, when lever is pulled back it will pressure cylinder and release pressure when lever is pushed forward.
1/2 inch pipe opening toward rear center of unit pointing to rear of tractor was used to pressure a IH remote control valve for two way pressure.
