656 utility brake lock pawl?
tomstractorsandtoys
I have a 656 utility in the shop right now and the pawl is worn off on the brake lock. Is there an aftermarket replacement? They are no longer available from CaseIH. Dealer says all utilities used the same 404,340,656,544,460,606 ect. I might be able to build this one up and grind it down but as it is a safety item I would sooner buy another one as we plan to sell the tractor. Thanks Tom
That give you a wide range of tractor's to choose from, for a used one, Not aware on any after market, I would think Steiner's would have it, if there was one made.
(quoted from post at 13:36:04 02/13/17) I have a 656 utility in the shop right now and the pawl is worn off on the brake lock. Is there an aftermarket replacement? They are no longer available from CaseIH. Dealer says all utilities used the same 404,340,656,544,460,606 ect. I might be able to build this one up and grind it down but as it is a safety item I would sooner buy another one as we plan to sell the tractor. Thanks Tom
I am having the same problem:
Farmall 656 Park Brake keeps popping outhttp://forums.yesterdaystractors.com/viewtopic.php?t=1345463
