Bad hydraulic pump?
ih656
Been messing around with my 656 hydro that's had bad hydraulic problems since I bought it. Found out the unloading valve had two bad orings. Fixed that and I got my 3 point hitch to work like it should. Now my remotes don't work like they should. They have gotten a little better but not by much. So we think it's a bad pump. But want some others opinions to.
You can throw money around like water on well lets change this part out , oh that did not fix it so lets buy this here part and that will fix it , oh that did not work out like i thought it would so lets buy this here part . when working on Hyd. best money spent is on having the system flow rated buy someone that has the equipment and the knowledge on how to use it .
