Bosch VA Injector Pump Seal
Go4Broke2
Does anyone know where I can get a driveshaft seal for a Bosch VA injector pump? I have a IH 574 and the pump is putting diesel into the engine oil due to the leak.
Thanks
Check the shaft movement side to side and up-down. If the bushings show any wear and shaft is not centered a new seal won't help. Used to be the bushings were not replaceable, but now Bosch does supply them. Pump must be apart to replace them as a special reamer is used from the rear to machine them to size again. Just did the bushing repair on an older VW auto pump. 17 MM Bosch seal # 1 460 283 312.
Thanks Dieseltech. That's good to know and I'll be checking into it. Hopefully the bushings will still be good. Thanks too for the part number.
