Stage II SH Hydraulics
Hey guys! Wanting to get all the fluids changed on my new Super H. I quickly skimmed through my operators manual and did not see anything about the stage II hydraulic systems. I'm assuming I would use HyTran in this system just like my 300/400's. I see the where to fill and drain the reservoir, but is there anyway to check the fluid level? What is the capacity? Thanks for the help!!
Operators manual # 1-004-371-R1 printed in 54 said to use IH touch control fluid. That progressed to hytran. Supposed to see fluid in lower fill opening when full. You must have first or second print operators manual.
Touch control fluid == Hytran
You fill it until it's full. It's more than a gallon, so if you get a 5 gallon bucket you will have plenty for multuple changes. If I had to guess, 6 quarts like the belly pump.
Manual lists capacity of 7 quarts. Four different manuals that I know of. Number 1-004-373-R1 is the latest I think.
