my tractor is fouling the first 2 plugs in front near the radiator. the 2 in the rear are ok. the exhaust manifold in front across from the 2 oil soaked plugs looks burnt not like the rear one. It is also smoking and blowing an oil/ gas mixture out of a hole on the underside of the intake manifold and getting it all over the tractor. I posted this yesterday on the main forum and one person told me I would prob. get more answers on the formal one.So far it has been recommended to change plugs, do a compression check, It was also said to adjust the valves as that can be part of the problem.some said that they think the intake has a hole in it from rusting through.The hole looks to much like a prefect one eight inch hole that has always been there.Thanks
Howard
Howard
