put new bushings in the bolster top and bottom, followed the directions that I got on here, I just did the 350 a few months ago also, on the m I also put in a new worm gear bearing along with all the seals and a new thrust bearing, put it all back together and when i tighten the steering sector gear(half moon gear) the tractor will not turn one way usually left,(tractor has power steering and the pump will not turn the wheels then)i loosen the cassel nut up a bit and it is fine however I am wondering what I did wrong I pulled the new bushing flush wirh the hole it fits into, top bushing went in okay,sure I got the thrust bearing in the right way, I was told to pull the bottom bushing up higher how would that help as the bolster shaft would just rub on the tractor casting then? I am only about a half of a cotter pin off when it I tighten the gear down as tight as I can get it, if I back off one notch in the nut I am okay then, could the splines on the gear be worn, there was a suggestion to take a few thousands off the bottom of the gear, would a new gear help? thanks.
