loader on 560D
Hayfarmer
I purchased a used Dual loader I plan to put on my Farmall 560 or possibly my SMTA. does anyone here have that combo? wondering how long the axle mounting brackets should be for those 2 tractors? Woods was nice enough to send me an operator's manual but they don't have any info on the mounting brackets for particular tractors thanks in advance for any help
So you're wandering what the width, is, too bolt from the tractor rear axles? Measure the width of the Loader upright's and go from there. There about the same tractor , my brother goes from a 706 to a SMTA, back and forth, with very little adjustment.
I had a 320 dual on a 560 once. Took the loader off and put it on an M.No problems that I remember. Seems it fit either tractor equally well.It seems the mounts were the same for either tractor.Could probably put on a 400/450 equally well.Had it on the M for many years.Only 'down side' was the 560 had power steering,the M did not. The 560 had LPTO,the M did not.So you had to put the M in neutral and let out the clutch for the pto pump to work.
on the Dual I think there are different mounting bracket lengths depending upon the tractor. was wondering if anyone could tell me the correct ones for 560 or smta
