I posted awhile back about a Farmall H pump that was filled with a mouse nest and had rust issues in the ball check valves. Found a NOS pump body and now have her back together. In the Lift all manual it describes how to make a hand crank so that you can bench test the pump. However it requires a 15060EA coupler that you weld to this handle. New ones are $100 a bit much for a one time project.
The tractor is back at its owners and hauling the pump there and trying to hook it up outdoors not high on my list right now.
Has any one figure out a different way to bench test or does anyone have a coupler that is in bad shape??
