Yooper Farmall
Now that the holidays are over and it is too cold to do much else I'm getting a few Farmall projects done. I mentioned I am getting the radiator re-cored, and I'm ready to address the puddle of oil that is always under the tractor. We split the tractor, replaced the rear main seal and oil pan gaskets, also replaced the clutch disc, pressure plate and flywheel ring gear. This was also a good time to lower the lift-all pump and replace the drive shaft seal and retainer gasket and the pump shaft seal and gasket. It was challenging to get the pump shaft nut off, but a couple pipe wrenches did the trick. The tractor is put back into one piece now awaiting the radiator.
