Farmall H steering sector gear shaft end play?
Presuming you mean the bolster pivot shaft, vertical play can safely be 1/4" or more.
As long as steering worm is approximately centered between the upper and lower faces of the sector gear when the pivot shaft is fully UP (ie. when it is supporting the tractor), all is good.
