350 Utility Hydraulics
mwilke
I recently purchased a 350 Utility with fast hitch. It has two hydraulic control valves with broken levers below and right of seat. I would like put at least one set of remote hydraulics on tractor. I have looked at the online parts manual and have operators manual. Is it simply a matter of putting hoses and elbows on the existing remote valves? Or is it more complicated? Thanks for any input.
Those are regular t way (or one way if ser to S on their ends) The handles may be a real issue, they re splined to the actuator shaft, and can be changed out easily if you find new ones. Clean everything and keep photographing as you take them from one another. If you can't find levers, welding handles on those is very possible. They should look like the hitch lever. They have a steel splined bushing embedded into the cast aluminum. A steel handle can be made from ~1/4 inch X1" strap with a bend to approximate the originals, and welded to just the bushing, if aluminum welding is not in the cards. Jim
