Johnnykick
Attempting to start a 1955 Farmall 100 that hasn't run in a year or so. I'm not getting a spark when cranking. I have 6 volts up to the plug when the switch is on and 3
volts when the switch is OFF. I put a meter on the coil and get 1.4 ohms across the +/-, and 7000 ohms between the + and coil tower. According to a coil troubleshooting
site those #'s are good. I'm troubled by the 3 volts I'm reading when the switch is off. Thoughts?
