Super c distributor cap
Anonymous-0
I'm replacing my cap, running rough and just noticed a hairline crack in it. Done this before, but this time I accidentally had multiple wires off the cap at the same time. As you look at the cap, which cylinder wire goes on which location on the cap (as looking at the cap installed.)
Thanks in advance. I'm doing this in the pasture at -5 degrees tonight.
Looking toward the front of the tractor at the towers on the cap the No. 1 (one closest to the radiator) cylinder is at approx. the 1 o'clock position. Going clockwise around the cap from the No. 1 position the order in sequence is 3, 4 and 2 back to No. 1. Good luck, Hal.
