Farmall Super C
ligg757
I just purchased a 1951 Farmall Super C. The access panel for the box that has the light switch, amp meter, water temp and on/off switch is missing, does anyone know where to find this panel, I have checked several online parts sites?
If you have a 1-piece battery box, the battery box covers the opening. If you have the 3 piece box, the battery is exposed to the panel back side.
Thanks Pembroke, I have been making a list of everything I want to order and a parts manual is on that list, it looks like I may need to get a second job.
I did look at the battery box that I forgot came with the tractor minus a top cover and rusted out bottom and saw the two screw holes that attach the box to the area that I thought needed a cover. Jim pointed that out in his response about the one piece battery box.
