WTB: Farmall C or SC 37 1/2 axle.
tfringo
Hi, not sure if this is the right place to post this. I am looking for a good used C axle 37 1/2 approximately. Someone might have one out there. Please let me know. Thanks! :shock:
Wrong place , but anyone here probably has at least one
c,sc parts tractor. I have one in Louisiana , 318-542-
0896.
Have you looked at the axles or have them out? Need to know condition. Can I text message you? Thanks
(quoted from post at 17:30:58 01/08/17) Wrong place , but anyone here probably has at least one
0896.
I thought so but I am not vary familiar with navigating the forum. I thought I ran across it once. Thanks!
tfringo, Where are you located? To reduce the shipping cost, it will make a big difference. I replaced an axle in a Farmall C that was bent about a year ago. I was able to pickup a good axle in Northern Iowa. charlieu
I think I have one, plus bearing kits for both sides, seals and gaskets. Will check this AM and advise. I bought all of this years ago for a project that eventually was scrapped.
Mike
