CABOVER TRUCK-304 V8 HELP!!
I have a 63 loadstar cabover truck that had a 304 v8 in it. the motor was junk so i bought another,newer 304 engine,and had it rebuilt to put it in the truck.. im having trouble figuring out how the pulleys go back on.. the cabover engine has the fan on the crank pulley,and the belt runs to the water pump and alternator,then i believe there is a second pulley of the crank to run the power steering pump..also,there was a harmonic balancer on the old engine crank pulley but on the newer engine...do i need it or not? if someone has photos or a diagram of how the pulleys and belts run on a 304 in a cabover truck i would be much appreciated!!
I found a video on YouTube showing belts on a running 304 v8. I couldn't get the link but I would think if you typed in the following:
Kchs Redneck Scout 304 engine running
Hope that helps. I could not find a schematic online.
Todd
