Ccarburetor Zenith 213348
Before and after photos of a Zenith carb off a 1955 Farmall 100. I soaked it for about 72 hours in a solution of Metal Rescue. Amazing stuff.
Question: I have blown air though all the orifices except the one marked in red. Does any know where the exit would be, and tips on clearing it? Thanks.
Here's the photo.
I have a little hand held chuck and use numbered drill bits to clean the passages and spray bomb of carb cleaner and a mag lite to clean all passages
(quoted from post at 16:12:10 01/08/17) Before and after photos of a Zenith carb off a 1955 Farmall 100. I soaked it for about 72 hours in a solution of Metal Rescue. Amazing stuff.
Nice job cleaning. Should work good once you put it back together. I think the hole you circled in red is an overflow hole to drain the bowl if the float gets stuck or if the float level is set wrong. If the float gets stuck gas will drain through that hole and drip from the plug in the bottom of the bowl casting. That's my recollection.
