Farmall C/SC axle retainer bolts..
tfringo
Anyone know where I could find the retainer plate washer and the two bolts for the axle for my Super C. I seem to have misplaced them. Thanks
Thanks. I purchased an axle off eBay and it was junk. Got my money back. Took it to the machine shop and stuck a bunch of money into it and it still has problems. Not sure if I should yank it before I got it all back together. I seal surfaces were badly pitted. But, now I found that the bearing must have froze on the axle and wore down the bearing surface. Should be tight fit. I can jiggle the axle. Probably will work but I don't like it that way. Hmmmm
