560 Farmalls
I have been working on a pair of 560 tractor last year and though I should post some of the results. I still have a long way to go in making them into the machines I want to use for recreation/work if they get that far.
OK so the videos did not work. I will try again.--Well it seems they are the wrong file type so I will need to convert them hen I get it figured out.
So far i have put sleeves and pistons in the original gas tractor had the head gone completely through, rebuilt the carb and worked on getting tires on it. The diesel I bought a used engine with a knock. I put the diesel crankshaft in it with new bearings,honed the cylinder walls and new rings on the"more Power"pistons. The head had already been gone through. I used the diesel engine oil pump in the gas engine. I used the diesel starter, clutch and flywheel on that one. I picked up misc sheet metal parts and hydraulic components. I still have a long way to go before I can enjoy using them.
