460 gas rebuild kit
gstout
I have a 460 gas c221 that is getting tired, I have been told to get a cleveite kit. are there any that are better? or any specific ones to stay away from? I will use the tractor mostly for haying, but if I need to hook a plow or harrow behind it I don't want to have to worry about working her within reason. not wanting a hot rod tractor, just a dependable stock that I am not aafraid to use. thank you all in advance for any help you can give me.
Anymore it really does not matter as long as the sleeves fit correctly since there is no real quality in any of the rebuild kits . There are only a couple places making the pieces and parts and selling them to who ever is boxing the parts . then once you do get the sleeves in then ya have to mic each piston and mic each bore to fit the piston to the bore and rigid hone to get the best fit with the correct skirt to wall clearance , This is not no plug and play .
