560 loader for Duane NC OH
Hayfarmer
Back in December you posted a picture of how you hooked up your loader to a 560. From the picture I couldn't tell, are you running off the quick couplers on the RH hydraulic block and blocking the valve open? or is there another place to plumb into the valve? I am in the process of acquiring a Dual loader and wondering how bet to plumb it into my 560D thanks for any help
I think you would much happier with a PTO pump. A 560 doesnt have a good enough system to run a loader. A pto pump will put out 20+/- GPM. The 560 only about 12 on it's best day.And at about 1400psi,the pto should do 2000 psi.
