Steve Wilkens
A friend of mine has a very nice 354 (gas) tractor that he has cared for very well. Steering box rebuilt, power steering rebuilt, new carburetor, new distributor. Whatever it ever needed. Now it will run perfect for a couple of minutes and then start missing and die. Went through and checked everything. Compression in all cylinders between 119 and 128. was running too much fuel pressure, but have since install regulator and now steady at 1.5 lbs, didn't make a difference. Checked the points, and plugs, all good and properly gapped. held a light down the throat of the carb and fuel flow was steady when running great and when it started to sputter and die. Timing marks on the front belt pulley are a bit off, but even in adjusting the timing, no difference was made. Need advice, anyone run into anything like this??
