Farmall h headlight light question
mcrow4117
The 51 farmall h I am restoring before I bought it had been rolled and the light bar and lights were broken off. I found a bar and lights on eBay but didn't realize they were 12v which I don't think matters I can replace the bulbs and be ok. But my question is the shaft isn't straight at the bottom of the lights like the ones that were original. What would these go to and dos farmall ever put them on the h that was angled. Hope this makes sense. Some things are hard to explain thanks. For any help
Sounds like sealed beam lights first used on supers and maybe last of H tractors. Originally looks like left one in picture.
Here are two pictures of my 300U. 1955/56. These are original as of
the very early 60s when it was purchased second hand. Is all 12 volt.
I did the conversion many years ago but the sealed beams were GE if I
remember.
Same as Slater has below on the left side style. Now the rear "work/tail light" is a pretty fat teardrop style with the twisty knob switch to change red bulb for sealed beam work lite. Now before eveyone starts yelling. My 1977 CUB is set up that way. Come to think of it the 3ooU has a glass lense and two bulbs. Correct??? Also has the rubber gasket that falls apart when you need to change the bulb.
data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAoAAAARwCAIAAAD17XJXAAAAAXNSR0IArs4c6QAAAe9pVFh0WE1MOmNvbS5hZG9iZS54bXAAAAAAADx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6bWV0YS8iIHg6eG1wdGs9IlhNUCBDb3JlIDUuNC4wIj4KICAgPHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj4KICAgICAgPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIKICAgICAgICAgICAgeG1sbnM6cGhvdG9zaG9wPSJodHRwOi8vbnMuYWRvYmUuY29tL3Bob3Rvc2hvcC8xLjAvIgogICAgICAgICAgICB4bWxuczpleGlmPSJodHRwOi8vbnMuYWRvYmUuY29tL2V4aWYvMS4wLyI+CiAgICAgICAgIDxwaG90b3Nob3A6RGF0ZUNyZWF0ZWQ+MjAxNy0wMS0wNFQyMDowNzoxMTwvcGhvdG9zaG9wOkRhdGVDcmVhdGVkPgogICAgICAgICA8ZXhpZjpVc2VyQ29tbWVudD5TY3JlZW5zaG90PC9leGlmOlVzZXJDb21tZW50PgogICAgICA8L3JkZjpEZXNjcmlwdGlvbj4KICAgPC9yZGY6UkRGPgo8L3g6eG1wbWV0YT4KBZ9KxQAAQABJREFUeAHsvGd0VNmdvuvPN026Y3umPbZn7LHd7kR3Q9NkmpxzEso551wqqZRzjigL5ZyRkEBEASKDQGQEKCcUUI5136MjarA9s+69X/7ny+v1rrN2nTpVu3h6W0/99t6nfqbk/0iABEiABEiABP6XE/jZ//Ie2SEJkAAJkAAJkICSAuYgIAESIAESIAEJCFDAEkBnlyRAAiRAAiRAAXMMkAAJkAAJkIAEBChgCaCzSxIgARIgARKggDkGSIAESIAESEACAhSwBNDZJQmQAAmQAAlQwBwDJEACJEACJCABAQpYAujskgRIgARIgAQoYI4BEiABEiABEpCAAAUsAXR2SQIkQAIkQAIUMMcACZAACZAACUhAgAKWADq7JAESIAESIAEKmGOABEiABEiABCQgQAFLAJ1dkgAJkAAJkAAFzDFAAiRAAiRAAhIQoIAlgM4uSYAESIAESIAC5hggARIgARIgAQkIUMASQGeXJEACJEACJEABcwyQAAmQAAmQgAQEKGAJoLNLEiABEiABEqCAOQZIgARIgARIQAICFLAE0NklCZAACZAACVDAHAMkQAIkQAIkIAEBClgC6OySBEiABEiABChgjgESIAESIAESkIAABSwBdHZJAiRAAiRAAhQwxwAJkAAJkAAJSECAApYAOrskARIgARIgAQqYY4AESIAESIAEJCBAAUsAnV2SAAmQAAmQAAXMMUACJEACJEACEhCggCWAzi5JgARIgARIgALmGCABEiABEiABCQhQwBJAZ5ckQAIkQAIkQAFzDJAACZAACZCABAQoYAmgs0sSIAESIAESoIA5BkiABEiABEhAAgIUsATQ2SUJkAAJkAAJUMAcAyRAAiRAAiQgAQEKWALo7JIESIAESIAEKGCOARIgARIgARKQgAAFLAF0dkkCJEACJEACFDDHAAmQAAmQAAlIQIAClgA6uyQBEiABEiABCphjgARIgARIgAQkIEABSwCdXZIACZAACZAABcwxQAIkQAIkQAISEKCAJYDOLkmABEiABEiAAuYYIAESIAESIAEJCFDAEkBnlyRAAiRAAiRAAXMMkAAJkAAJkIAEBChgCaCzSxIgARIgARKggDkGSIAESIAESEACAhSwBNDZJQmQAAmQAAlQwBwDJEACJEACJCABAQpYAujskgRIgARIgAQoYI4BEiABEiABEpCAAAUsAXR2SQIkQAIkQAIUMMcACZAACZAACUhAgAKWADq7JAESIAESIAEKmGOABEiABEiABCQgQAFLAJ1dkgAJkAAJkAAFzDFAAiRAAiRAAhIQoIAlgM4uSYAESIAESIAC5hggARIgARIgAQkIUMASQGeXJEACJEACJEABcwyQAAmQAAmQgAQEKGAJoLNLEiABEiABEqCAOQZIgARIgARIQAICFLAE0NklCZAACZAACVDAHAMkQAIkQAIkIAEBClgC6OySBEiABEiABChgjgESIAESIAESkIAABSwBdHZJAiRAAiRAAhQwxwAJkAAJkAAJSECAApYAOrskARIgARIgAQqYY4AESIAESIAEJCBAAUsAnV2SAAmQAAmQAAXMMUACJEACJEACEhCggCWAzi5JgARIgARIgALmGCABEiABEiABCQhQwBJAZ5ckQAIkQAIkQAFzDJAACZAACZCABAQoYAmgs0sSIAESIAESoIA5BkiABEiABEhAAgIUsATQ2SUJkAAJkAAJUMAcAyRAAiRAAiQgAQEKWALo7JIESIAESIAEKGCOARIgARIgARKQgAAFLAF0dkkCJEACJEACFDDHAAmQAAmQAAlIQIAClgA6uyQBEiABEiABCphjgARIgARIgAQkIEABSwCdXZIACZAACZAABcwxQAIkQAIkQAISEKCAJYDOLkmABEiABEiAAuYYIAESIAESIAEJCFDAEkBnlyRAAiRAAiRAAXMMkAAJkAAJkIAEBChgCaCzSxIgARIgARKggDkGSIAESIAESEACAhSwBNDZJQmQAAmQAAlQwBwDJEACJEACJCABAQpYAujskgRIgARIgAQoYI4BEiABEiABEpCAAAUsAXR2SQIkQAIkQAIUMMcACZAACZAACUhAgAKWADq7JAESIAESIAEKmGOABEiABEiABCQgQAFLAJ1dkgAJkAAJkAAFzDFAAiRAAiRAAhIQoIAlgM4uSYAESIAESIAC5hggARIgARIgAQkIUMASQGeXJEACJEACJEABcwyQAAmQAAmQgAQEKGAJoLNLEiABEiABEqCAOQZIgARIgARIQAICFLAE0NklCZAACZAACVDAHAMkQAIkQAIkIAEBClgC6OySBEiABEiABChgjgESIAESIAESkIAABSwBdHZJAiRAAiRAAhQwxwAJkAAJkAAJSECAApYAOrskARIgARIgAQqYY4AESIAESIAEJCBAAUsAnV2SAAmQAAmQAAXMMUACJEACJEACEhCggCWAzi5JgARIgARIgALmGCABEiABEiABCQhQwBJAZ5ckQAIkQAIkQAFzDJAACZAACZCABAQoYAmgs0sSIAESIAESoIA5BkiABEiABEhAAgIUsATQ2SUJkAAJkAAJUMAcAyRAAiRAAiQgAQEKWALo7JIESIAESIAEKGCOARIgARIgARKQgAAFLAF0dkkCJEACJEACFDDHAAmQAAmQAAlIQIAClgA6uyQBEiABEiABCphjgARIgARIgAQkIEABSwCdXZIACZAACZAABcwxQAIkQAIkQAISEKCAJYDOLkmABEiABEiAAuYYIAESIAESIAEJCFDAEkBnlyRAAiRAAiRAAXMMkAAJkAAJkIAEBChgCaCzSxIgARIgARKggDkGSIAESIAESEACAhSwBNDZJQmQAAmQAAlQwBwDJEACJEACJCABAQpYAujskgRIgARIgAQoYI4BEiABEiABEpCAAAUsAXR2SQIkQAIkQAIUMMcACZAACZAACUhAgAKWADq7JAESIAESIAEKmGOABEiABEiABCQgQAFLAJ1dkgAJkAAJkAAFzDFAAiRAAiRAAhIQoIAlgM4uSYAESIAESIAC5hggARIgARIgAQkIUMASQGeXJEACJEACJEABcwyQAAmQAAmQgAQEKGAJoLNLEiABEiABEqCAOQZIgARIgARIQAICFLAE0NklCZAACZAACVDAHAMkQAIkQAIkIAEBClgC6OySBEiABEiABChgjgESIAESIAESkIAABSwBdHZJAiRAAiRAAhQwxwAJkAAJkAAJSECAApYAOrskARIgARIgAQqYY4AESIAESIAEJCBAAUsAnV2SAAmQAAmQAAXMMUACJEACJEACEhCggCWAzi5JgARIgARIgALmGCABEiABEiABCQhQwBJAZ5ckQAIkQAIkQAFzDJAACZAACZCABAQoYAmgs0sSIAESIAESoIA5BkiABEiABEhAAgIUsATQ2SUJkAAJkAAJUMAcAyRAAiRAAiQgAQEKWALo7JIESIAESIAEKGCOARIgARIgARKQgAAFLAF0dkkCJEACJEACFDDHAAmQAAmQAAlIQIAClgA6uyQBEiABEiABCphjgARIgARIgAQkIEABSwCdXZIACZAACZAABcwxQAIkQAIkQAISEKCAJYDOLkmABEiABEiAAuYYIAESIAESIAEJCFDAEkBnlyRAAiRAAiRAAXMMkAAJkAAJkIAEBChgCaCzSxIgARIgARKggDkGSIAESIAESEACAhSwBNDZJQmQAAmQAAlQwBwDJEACJEACJCABAQpYAujskgRIgARIgAQoYI4BEiABEiABEpCAAAUsAXR2SQIkQAIkQAIUMMcACZAACZAACUhAgAKWADq7JAESIAESIAEKmGOABEiABEiABCQgQAFLAJ1dkgAJkAAJkAAFzDFAAiRAAiRAAhIQoIAlgM4uSYAESIAESIAC5hggARIgARIgAQkIUMASQGeXJEACJEACJEABcwyQAAmQAAmQgAQEKGAJoLNLEiABEiABEqCAOQZIgARIgARIQAICFLAE0NklCZAACZAACVDAHAMkQAIkQAIkIAEBClgC6OySBEiABEiABChgjgESIAESIAESkIAABSwBdHZJAiRAAiRAAhQwxwAJkAAJkAAJSECAApYAOrskARIgARIgAQqYY4AESIAESIAEJCBAAUsAnV2SAAmQAAmQAAXMMUACJEACJEACEhCggCWAzi5JgARIgARIgALmGCABEiABEiABCQhQwBJAZ5ckQAIkQAIkQAFzDJAACZAACZCABAQoYAmgs0sSIAESIAESoIA5BkiABEiABEhAAgIUsATQ2SUJkAAJkAAJUMAcAyRAAiRAAiQgAQEKWALo7JIESIAESIAEKGCOARIgARIgARKQgAAFLAF0dkkCJEACJEACFDDHAAmQAAmQAAlIQIAClgA6uyQBEiABEiABCphjgARIgARIgAQkIEABSwCdXZIACZAACZAABcwxQAIkQAIkQAISEKCAJYDOLkmABEiABEiAAuYYIAESIAESIAEJCFDAEkBnlyRAAiRAAiRAAXMMkAAJkAAJkIAEBChgCaCzSxIgARIgARKggDkGSIAESIAESEACAhSwBNDZJQmQAAmQAAlQwBwDJEACJEACJCABAQpYAujskgRIgARIgAQoYI4BEiABEiABEpCAAAUsAXR2SQIkQAIkQAIUMMcACZAACZAACUhAgAKWADq7JAESIAESIAEKmGOABEiABEiABCQgQAFLAJ1dkgAJkAAJkAAFzDFAAiRAAiRAAhIQoIAlgM4uSYAESIAESIAC5hggARIgARIgAQkIUMASQGeXJEACJEACJEABcwyQAAmQAAmQgAQEKGAJoLNLEiABEiABEqCAOQZIgARIgARIQAICFLAE0NklCZAACZAACVDAHAMkQAIkQAIkIAEBClgC6OySBEiABEiABChgjgESIAESIAESkIAABSwBdHZJAiRAAiRAAhQwxwAJkAAJkAAJSECAApYAOrskARIgARIgAQqYY4AESIAESIAEJCBAAUsAnV2SAAmQAAmQAAXMMUACJEACJEACEhCggCWAzi5JgARIgARIgALmGCABEiABEiABCQhQwBJAZ5ckQAIkQAIkQAFzDJAACZAACZCABAQoYAmgs0sSIAESIAESoIA5BkiABEiABEhAAgIUsATQ2SUJkAAJkAAJUMAcAyRAAiRAAiQgAQEKWALo7JIESIAESIAEKGCOARIgARIgARKQgAAFLAF0dkkCJEACJEACFDDHAAmQAAmQAAlIQIAClgA6uyQBEiABEiABCphjgARIgARIgAQkIEABSwCdXZIACZAACZAABcwxQAIkQAIkQAISEKCAJYDOLkmABEiABEiAAuYYIAESIAESIAEJCFDAEkBnlyRAAiRAAiRAAXMMkAAJkAAJkIAEBChgCaCzSxIgARIgARKggDkGSIAESIAESEACAhSwBNDZJQmQAAmQAAlQwBwDJEACJEACJCABAQpYAujskgRIgARIgAQoYI4BEiABEiABEpCAAAUsAXR2SQIkQAIkQAIUMMcACZAACZAACUhAgAKWADq7JAESIAESIAEKmGOABEiABEiABCQgQAFLAJ1dkgAJkAAJkAAFzDFAAiRAAiRAAhIQoIAlgM4uSYAESIAESIAC5hggARIgARIgAQkIUMASQGeXJEACJEACJEABcwyQAAmQAAmQgAQEKGAJoLNLEiABEiABEqCAOQZIgARIgARIQAICFLAE0NklCZAACZAACVDAHAMkQAIkQAIkIAEBClgC6OySBEiABEiABChgjgESIAESIAESkIAABSwBdHZJAiRAAiRAAhQwxwAJkAAJkAAJSECAApYAOrskARIgARIgAQqYY4AESIAESIAEJCBAAUsAnV2SAAmQAAmQAAXMMUACJEACJEACEhCggCWAzi5JgARIgARIgALmGCABEiABEiABCQhQwBJAZ5ckQAIkQAIkQAFzDJAACZAACZCABAQoYAmgs0sSIAESIAESoIA5BkiABEiABEhAAgIUsATQ2SUJkAAJkAAJ/Ew5dVGV6f5K5fh55UTD3FCNcrRh8G1x9/O8luvxl8r9Kk/LCxMdi5NlZalepSneZ7ICLpdF3T2XdP9C8us7eYOtNf0vK/pelPQ+L+1+VtJ6L/f2uRi8JD3CNDHQMMjlaJyP3qkAo9xYp9IUj/r80MvlEY8bE1uunXrWlPbyVmbHw+LuR1WvbxbdP5f2ojGnMll+rSy8Ic+/NN7xTKq8IMIi1G6/q/aaFG+t7DDD4iSbmnxFQrh+sM+JUxGGiUG6p8ONy1IcAxz2elru8DDf5mqyyclwU4CLWoibVoS3QYyfSYibjo/9CWfjvdbaW0zVfjI+tt5Kc6ur6UEfG3VHvb1y0yPBzno42mntcjU8aK2x3fDQOpOjGxE0jI9ssFLfhqdw3stKDRdYntxseGiN7sEfDI/+aHZyo7XWNiuNnfoHN+vu22x8ZIf2nk16+7ehYXp8u5naNtMTmw2Przc4tkb32Gqdo6u0D69Gju/+1lh9i5n6dnONHQZHN2vuW6t7YC2udDM7ILfY72a6291kd5DdcT+rI/EKg2g37Tgv3fJUl5wYi6RArarTzrU5bllRxhHuh1OC9KIVJ7ystzsbrHMz2qAw2+JruyvQaZ+fza5A+z1BzgdCXQ/hJWFuByMURzMijVLDdPMTLeoK5I1n/BtrPe9fDnz3MHHgdfbYu+LRt0XDrQVDr/JfNMU0VrijPdlZPvwi/82tU01VXrWnratPW725k7jQX6ccqB94nnv/XBAeojH0qrDrUcbgy3zlcMNsz5m2+6lv7iS8vhXX1pzy6ErE+UJZUZJ5pNeRQJcD/o77g12PedsekJvvcjTYbK21ztlku43uRuMTP+gc+F573486+9bpH/rJ6Mjmkzt+1Ni9WmvPGu29a7X3rtbZt0Zn/yoAt1Tf4G6x18fuIEZUuNuJUJdjAQ77fW33+Fht97PdEeSwM8R5T6zn8VCX/d6W22SG602PLFPFRn2l2dFv9fZ+rrn9d8d/+s2xjb8+sv7fkMPrfnVo7Wf7V/1izw//vGv5P6JxZOOv1bb+7viW/zi66Tf713+2d80vt3339ztW/OOeH3++b80vcXLvql/g2f1r/0V84e4V//eO7/7+wOpf4j0RNPA+eDc0cAHOeJhsD3Y4ZKux2uTQtzhzcNUvDfZ8cXDNZ5rbPj+26Q8bl/180/LPdqz5w9bVf1y17Dcrv/71j9/8du2y/1j37e/Wf/97VfZsWrFhxeerv/09jmu++8+VX/0WQWP1N//+0w9/wnHjij+u//Z321d9sXPN11tW/nHj979e/91na7/7V2T3hj9vWvHv65f/+qeV/4FekM1rxHy+ec3nOzZ+uW/bd8j+7d/v37ps35av921bhuzZ8tWOjX8+vHu5Kgd3fY/zW9f9fs3yz5ANK3+zdf1/7PjpD4d2frl/25/3bP7D3g2/3/7dLzZ98ffIzu9+sfO7f173h/9t6zf/iBxe99s9P/wLGgdW/cpFb+uWr/5hw+f/B477Vv9q54pfbv32nzZ++X9t+PLvf/rmn9Z//Q9rv/y7nWt/u2bZP337p/99xZd/t+zz//PbP//dd1/8/fdf/POyP3y2etmff/z2T1//6Tfr1ixbu2bZmnXfrl6/lHXrlyPLf/hSzI/Lv1zz7Rerv/78xy/++MPnv0dW/vk/V3zxO2T1d39cu+Lz9au+2Lj2q20bv9uz9cf1K/+8ee3XOG5Y9cVPq7/cvPqrPRuXC/npO+Tg1pVCtq1ATu5fr3HwJ+0jm3WPbdU5usVAbSeChuaRzTonthlr7zXX3x/gaRzgaSjGT67rZnvcznS/rclehZO6t4sWzgR4GAS46fq6aHs6a+IkjkLDRYi3m56XTBfxdNVBFM7aiIeTprP1CVWsjA/YmBzEQw8nPKurSoCHkbeLDoKGn5u+KqHeZuJ5NPzlBj6uup54W0dNvDO6QI9+7gaeLno+csNgH4twf5sAham3zCDMzzrIyzzc3y7MzzbY2yrQ0wLxdMGVBmjgpCoRAfaxoS4IGpGBDqE+1ggaIX72QT42/p42fh62ChdLmZ2xk42xi72pq4OZnaW+pZmOuYmWtYUBYmWOh3p6uur6ehpaGscszY0N9XUtzU21NdVPnjimo4WTJxE0Dh3Yd/TwIbXjRzVOqh0+fHDfvj3bt2/dtHnjunWrVNmyZQOyafP6nzat27BxjSpbd2zdvA1n169Zv2bthrXrNq7bsn3Lnv17cMT5n7Zs3LhpA57CBXi4fee2A4f37tq7Y9/B3SfUj2nqnFRF11DbyNRA30hHTeP4/kN7VMELN23dhBfu2rvr0NFD+w/twxvi/Q8fO4yHBw7v33dg79HjR06on0AbV/5MOXIWum1vSblc5Yb0vcpSjp6bGage7Sx725z2/HbijbOBZ3Lc8hJs08PNMyKsTvmbxfuapIZY5ic4Xa2MuFUf+6wpo7Ol6Mn1pOe3UlvvZ759mPvkekrT2ciqLLfsWIsw+TFP6534i+lrfyDQ6ViITC3SQyfWWxdPZUYbwwpp4UZx3ur+9vvczbYiboY/RbgejlWoJfpqueis8bfa6WO6yerIV75mmwsijbJC9eJ9T4S4H4rwV4sI0gj1F9r+DrtivU+EuBw0PfaN4ZFvdA9+obX/c/xZNzi+Uv/YDwgahkd/0D+yQu/wcv0jK42Pr3Y03OHnqAbbyYz3nfK3iJDrO+jusNbcbKu1xfzEBhfD3WgjaPjYHscR8bI6Guio4W1zRGayx05/C+ThYrpDbrnb3fIAHAx9Wpzc7qh/yMNCw9Nay89BN8hFL1SuFwtWkTbZCc4pUTbxIWah3roBck1Xq/3ezmqZsa7JYQ7hClM/Jx0/B+0QmV5auG16hA0gZ4Ra5EbapAeZFsU6Zodb5MVa1+d7lKfZQWYNRe4tjXFn81yKky3OF3qcyXIuPGWRGWmQE2mYF2OcH2+Gh2WptpUZDjXZLmdzZQUJpqUpVmUZtkhhsnlJmmVFpk1ltnVltnlVjuXZfJvzxQ6XK1wvFDveOuv55m7c4yshjy4Hv7t/qrM5efBV9sDz7J4np7sepb27n9T/LOvDm0JIGnrufpwOZyN4tu1BMo7jbSXI61sxbQ8EqX9oK+x+mt5yLaLprO+ZLMeiRMu8WPOCeGv8WzLDLVKDjZP8DTIjLaO9Ndwtt1tprrXV2oT/FiAcpTAMctIEdjeT/Y76OxUWh9AOdtHAsMmMtK7L92soCbhY7Hf7bNSt2simmvAbZ0JunglqqvZvrPC6Uurx4Hz4/XNhd+vC75wVjqo8bIhCu6kqsLHc72KRZ32OvDLVoTjBKj1YNzVQO9FXI8FbDe2ieMu6PPfr1cF36iPP5sqTQ3QCnPf42Gz3s98Z6LQnxGV/gp9GSrBO4Smr0mS7siS70kSbklPW4vvgTRC8SU6kcV60Gd4Kz+KpB+eimxviylPs82PN0Yuf5VaZ/hqzo9/gO4Hp0e/VdvxRY/83mgdXqO1fcXjntzvWf75rw5e7N361Z4OQg1u+O7F7lfrBdSf2rj2y88eju1bjr/++zd9v/vE/kQObv929/ssDm7/e8uPvdq390/Yff79h2a/Wf/PZlu//bfuPnx3d9sejO/60c+2vNPZ+rb77m/2bfv/T8p9v/O4Xezf8YfeGP6z//l9WfvmPG5f/608rPlv11T9t+uFX67//xaYV/7Jj9W+2rv715h9/tXH5L9d99/Mtq/5NlU0r/3XNsn9Atqz6bOOKn69Z9nc71v1K68iyEA91b6fDrha77PQ32eusc9Ba62a42d92f4jTIQ/Trf62ewPt9uGY4KVZnuycE2FeFGfrbbEj2l0tUnbMx3In2gqzbcL//U23+1jvDXM7cSrAICfewd/1uKnGao39X+3Z9O+7f/rtrg2/2bnu31f86edrvhK+oOBryoqvf71i2W+///a333zzm6+//vVXX/3b118iv/lh+R/FrF7x+cYfvty4/Iv13/1p7bI/rPrq96u+/o+lLPv37//82doffnd4148nDqzXOiboU//kTlOdfRb6R+xMT7pYajmaqjsJUUNkFhoulhouVicRV2sNdxstT3sdb0d9PxejYHdzxNfVSG6rpXDU9XEx9JcbBXmbBnkbiwnxMoZ05XYnEKjX310P9g1UGIYojILcDXDGV6bj46qNeMnE/Df2hYDljlqqQMBG2jv01bfiqDqJhoeDhtzuJOJur46jm62aGGfLozgD7/rK9ET1wsdow7v4roBPG+xjFuhpBvtGBNhGBdvDvpA6fIzAsnBwVJBjTLAT2lAvZKyyrOha8Vlc5u9h5uVqiKPYCPS29ve08vWw8naz9Hazljuawr4yRwto2MJYy9jgpJmxhpmRlp7WseNHFj24bePhQ7t379q8a+emo0cOqKud2Am5bly/bs0qIwO9vbt3fb/sm5Urlq9ZtXLDurWbf9qwceN6MRs2CKJdv361GNh3409r16xduXLl96tWrxCzes0Pq9b8iPyw6ocVP674/MvP4cuDRw4eUzu6Y/d26HD1ulXLVy5f9v2y75Z/iwau+WEVjt+vWvvD+k1rP82mrRu274Kzf1q9buXKNSvELF68Aq9auXolesEbwujQOY7wMdwv2n33vt0IJI3efzbZWz7WXfrybmxdkd3FCheYGGcG3uT2v859div+4dWohlJFxWmnrGiL5CCj1BDzKIUu/hQm+Bvir+fZPK/G6tDmq6eg3geXo+9eCL9ZH3K9JqjxTOC5YkVJqn12rFmc38kw90ORnie8bHc6Ga2311tnpbnaQv1HC/UfrLR+tNX50U5vpdx0o9xsvb/jtjjfw0FOm8NkO9xMVuDob7MhTrEvWrZTbvB9vMe+0jjjzFCNlJCTKZE6xdkOFUVuBVn2uSmWcX4nUGPF+5/0sd+psN0pt9rqYrEZcbPb6SM7FKQ4HheinxBicCrMMCncOMJHIyZA53ScVUWOR31pwIPLyU+bMpGWG6dxvHcpCWde3s1rbylD0Oh7VYO8uJPTWBNx50LCw6tJz29nvnmYe+VMwMVKv4Zy7/OlfiVpsqxY+9PRdnkJspQwm4xI+5w4p7xTTlXZHg1l/rcvxbTcSnvRnNNyJ/1OY8KNCzHInauJ+AD5yc65Sc5JYZZx/saJwWZpEZal6W5Xq8Lu1sc9b8xovZk53XFuvvfCRGe1cqRhsrtiBlMUI3VTPeWT3WU4TvVVjXdX4KvSh7bi0faSgVe57Y9SX92JR2PwbeGHjpKxrnI0Zt/XKkfqcTG+aeGr1eJ/8eK5oerpgfLxnpLRroLh9pzOJ4m9L1Ine4omugsXhipn+kvnhivnR6pwnHlfPj1Q+v5t1mBr5vC77A/tuaMdeVO9xbhsuq8E1+PheGcB2jg51VuoHKue7i9aGCqf6M4feJ3R+SQZGr591h92vFLqWZPpfCbDuSrNEf6rz3K7VKC4Ue5/tyb0ZmXwraoQ5E51aFNV8MUib1xTFGedEWaUDZkl2panOVyrCmi5mtBY6d/3vPBDa/nom4rxtoqJ9oq53uqZ7vKJjqKxtvzRd3ljbYXj7UUTHSWfZry9YPHZnA9vs6e7i2Z6Smd7y+b7K5G5vvLpblwsnERbOXxG+aEWmX9fNdZdPNKRP/w290N7/kQX/nWlcwOVyHhnER5OdhbjheJb4YXoAkFj6X0Gq5XDNbgAHeEMekc+vM3tf57+7n788+tRDy+EXC5XVGbZFyVbZcZapESapkSaR/ga4o+yt5Omh81xfxftELlBtI95fKB1fKBlrL95mLu+n6O6i8k+X4fjCL4LupvvD5Gph7lpJAeYpgaZJ/rim41RdrhZUZzJuVyHi8Wymizbuhz72myHkkTT1FBNTIckBeggIW6HNff+XmvfHyw0lrtbbvWx350cpJ0RZhCtOGarvcJC4zuzk9+YqH1trr4MbTHedjtifY9nRBlkRhtiKqUoxeJypU/r3dSRt2V9z/Pf3k973pTw9GrMkyuRr28m9LRkvX+R9/ZuEhq9T7IxR4LgPM48aAjGDErTGe9Hl8LRfnwh7MnlCLyq90nuixvCO7y9m9rbkv/kWvyts8E3agJqc1zxhRJTX/lxVvHeen62h/F1zejoGlP1jcbqm4w1NxtqwUPbjHW2m+nsMNPZZWdyWBUfZz1Pey13Ww03q5OI3EZNjMzqmKPpAU+HkzGBVmEeJkicv02snzUaoe6mfxNjnA9RCAn2EP4DhbobhnsaR3jhYsNIb1MEjTCFkXgywsc0zNc01G8pp8IdogIscSbczxwRnvIxEeJlDAdDxlCyGD8PPSGw8sf4yPVV8XM3+jQuNictDPbBxKryFw1RqzArGi5Wx1QBGUfzw5AxTIy42pyAj1EBi/YN9TUPD7CCepHIQDsIGLUv6mD4GI0AhbkoXdgX6kWNC7k6WJwI8rJURZQ0HsK+4jW4DA2Uv3Cwn8LaR27l4WzhamvkaG3kbGdioqdmoH3USF/NylzXxdHM0c7E1kofRbCVpYGNtbH6yUOHDu5CdLROqp88pqF+XF9PSy5zwlHt+OFDB/bs2rFl/bpVPyxfBr+qAuOKQdWLoC0qWVUWo4FKFyKEbnfu2QH1wpGQsejjRd0utWFfOBgmhlPXbli9cfM6RCVaNJav/E48fvnN59//sEwVVNUwLuwLB3//w3d4TzzE+3+17Cu8IU7iAtHKkD3aPxtpL1RltLMEQREMH79/U/D8dsLjazGXKrxQAeefskMFjBIkPdwyLcwiJ9a2IkOGMvfl7Yze58V9L4sG35YOvysbaSsf7aiaH2qY6q0dfluB889vJWMSG/VxQ6kX/k+LqjfeXyvc/WiCv25GpFlZunNdgcelMs97DaHPbkS1XAtrvRM99Dq792nai6aIvpbUD6/zOu6eaqqQt92Oa7+X1Ho7fqKzcmqgfmb44tTopckPFz/01Pa8Lu54UTDUUTXWd+5Dd91wZ+1AR/X7zprBnrNDvXXDffXzkzfmx6/Pjl6dHr482CU8O9p/TjlxY2r4wlhfnXL21vyHy4hy8vpo79npoQvKqRvK8UYhaMzfUU5cE57Fw8XG1OC5sf4z472VI11lAygBXxW8uJt+81zkuRLfs4W+tQV+54r9L5QHXKkOenwj6eX91K4XOf1txQPtJf0dJf3tZUjn64KOV/n4zI9vJt+9En+hMqgm3wvJT7KtzpZfqQy8dz760eW4J1diB57l46/YeGfJTH855Aex9b+GJgsGWtOgt6n+EqhxdrACQUOw5kA5fImHcKdyrFY5WYeHyg/VyvGzi6lWjlbNj+BZIR/lWjw9UDwzCOOW46TyA5YhcH21cuGccuqMcrJ6YbxifqwcUY5VzH8omxoomB0qUY5XKieqEZxRjpbjKJycqZ0bKVZOVgrHD6ULg0UzvfkTnXnwzeOLgTerPW9UeF4qdLta6NFYpEDu14Y8a4h8dyOx515a152kztun3jXFvLkR3XUv8e3NmOeXwx+eD7yQ7yTmfIHTtUrPxgoF/mrj73j/05z3L3JQkcO1gkoHIM4K5Ui5cqh0fqBotg9dF871F88PCA/n+gtn+wrwYWb78uYG8pX4twyXoDHZnS38Q0bL8BCfVjlUrBwpFYIz+PzDwFIwNZA33Z83N1igHCkRziOTVaOdp6d7cvByvKH4KqExXIKggadwFN5wuARt4fxomfhQPConzuBT4RPiq8Bkd0n/y6zb9QH5SSaJwZoRHmpR3jpx/oZJIaangozFJAYax3pr4xtwcqB+tOJkVqR5fpxNQaxVTqRpXrRFebJjeaINvs1cLwt43BD3rimt7VZy553YgebY0Zcp02+zZ97ljDxL6W9JHH6R3v0gqft+SucDJA3ae3Mrvq/l9Ptn2fg/19jbgoXuiql3RePvCkdb84dfZg++yELQEKPsPzPdWTz2Nm/8Xf5MV8lsd/FcT8lCX+lCT8lcZ9FUW97Yu6yFvuIpfD/ryEMDGX5zerob5AsX3peNd+QguGbwZerwq7SR1xkDz5PRHn+TOduZv9BTpBypHXqe1tOcMN6arRyonm4vQpR9lRNvCoaeZXbdS35zI/7RudCGbFlRtHlepFlWpCX+ImVE2mKSKTXSLiXCFnNISJy/qRjMP0X6GIZ76Ye4awe6aWI1CmeQGB8jBI1TgeZJwZYJAWbhbnrxPmbBMm1fBzV/J61gV90wd8NQuQGC70BIkJtekFwnUK4T4KYdKNNGO9RDP0xhEO5pGONnhqAR62sW44M3R6fGgmjxhWkxsSE2eAjjRvhboB0daCU+hMsD5Xpi+SvMSMPEisV4GPl/zOJUNmazhfh7mKgCNYoyRtmqOokGqlvMMCNLM8yYZHbURFmsCrwrqldVAaMvsQKGcaFbJNTXEu24MGccIWNUt7ApFCsWu+IstNxBB2JWxcfNGOcRNPzkJuI0NRruzoZujnqudnrONvqOVvrWJprmRhpWJtpaagd01Q+hAra3MXKwNbazNhSno83MtE2MtTQ0DhsbadramrjL7R3szeztTD3cHb09ZYiHu7PczcHR3trM1FBPV1NXV1ND88TRYwcPHNzzafbu23n48H51jeO44NjxQ6pg7vek5kltPW19Qz1rO2szC1MNLXVMFGNaGD5GYQo3ozZVTVOj9kWZi2IXJS9KYVXWbURdux5HnMEFYrZs3yTOY2NmG36FbmFf1L54CAeLDyFdRJS9UAFjwnkpI3XK4bPKoVoxc/01o+1lWAN+2pR893zs+WL/6izPuryAmhzfs3k+VypCH15OfPMga/BN+Xj3maneM9P9NbPv8Q7nlaMXhQyfnxk4O9lTPdNfjwug576XBU+bEu5djLhU7nMm17U6W1Zf6Hm5IgAV8/0LYS9vJby6E/voalBHc/yLm2Fv7kY9ux5897zn6JvcEUyEPkvveZSEvwWoafDBlBNXlJONyulryplrwhGZvS5krgk2Vc4tZr5JqcrCdeU8nm38r8xeVYqZuawUM31JqYrqJBqqk3/RuKCcuzQ7WjPSXdTzOqv9cQa+ZNw6F377fNSDS/i2kQIynU/yBloLUZ5O9FfMDFXNj9XOj9XNjgtRTjbMfKgd7asc6SnvfZ3f/jTnxb3kR9fjm+qCr1b4NBQprp/xv3s+pPly+ItbsZ1PUlGBQbozA4VTfbkzA/lioIS5YaiiXFDIRx0KUpxc1CcMOlmzmMUzUCmCZwXfCL5UTkKutcopSFrw6OI7wKmLwZUztcrZauVUpZiFyXIh42V/m/mxUlUWny1ZGIeeS5RjMFmxcqBgsj2r/2nKu1vR98/6NBa7Xsh1bCyU3yz1ul3hg7xoCO+8mTjwIO3D07SZN9kL7fkQxvuWxP7m+O77Me13Ix9f8Llfp2iqlF0pdbxe4Xb3rPfTK+GYD3979xSmwT+8yRdKzD4Yt2D+fcGiC6G9QmQByhwoWOjP/zQ4o3xfhBpdOVg63ZU7+jZjoa8QUQ4UCXlfImSoVMzCML6UCEFDFVHwcPl0T95Md95sT/5cb4Eq4rvhnzzVmYOgCwSXIbhG7AjqxUddGMgW0p+Lj4dnR99kv7sTc6/OryrdtjrdCSv9ZzJdMYONeYIzpx1rs1zqs1wv5suvl/ncqfFvKve+ixFyRmhcznWqT7c+k2yO4+VsxxuFbi1ngzpvxvXeDR96FDHxIn7mXZqyr0DZnjnfnrHQkT3fnqnsKVT2Fs625yHznXloK/vguSJlb76yR8hcZzYy35WjykJ3LrL4MGu+S8hCd/ZCT+Z8T6Zw7D6No5C+LGU/3JmzlP7sub6svwqumes+PdmeMvwqrv9pJDLyInbibdJMe6qyJ+fDi4ThJ7GTr5OVvQWqzL/NmnieMvgwtutmeFdTZEut96Vsu+pEi6Jo0+xwk7QQ4+QAw+QAHIXqP9HPMMHXAIUy1rmQaC8dBN9pkGgf4cwn0Y/zEhKj0I1w0w5z0QxyVg9wVAtwUBeDvSNC3PU+RjtYoYtA56rE+ptG+xphr0mYQk/0OnQeF2gWE2wZGWQVHmABB8O7MK6gZF+hMsaMNBLsaQT7ImLtKwr447LxknEXpSvIWCyIhQlhN2PEW2aEKWIvV30xaKMaRtAIVBiLwRowIspYtRKMBopjcSIabeEaT+NALxMxWO4VS144GHWwWA2jgdlmBBpWBT7+q6DYVQXeVcXXw8LH3cxLZqZwNXd3MhenoFEBi8vAqH2dHEydHIxdHE1kzuZurhbOzqZOTmZiFAoHmauVg72JlaWevZ2xs5OVk6OFtZWhpfl/RV3j6OEjew8d3n3ipGBZyPiE2hHYF5PPe/bsOHnymKaW2qFDe3HUN9DW08dKsrqWribsa2RqBAHbO9khtvY2aFtYm+MknoKhMRsOlS4uDP+0e99OLPHiCN2KokVjx+6t4trwwSP7tbRPwvTo/cjRA1A4FncRVNg4QufitDOkC93iDWF3VMDikjP0/ImAVSZG40ODcvDcUGsJLPLydtqNmvDzRYHVWd6VGZ6Vpz2qszwulvrfbYjGsx/aK6DeucGz0/3V4lQndm8JGamfGagRT84N1i/6uAbzpdjY1fHk9Ku7yTDx/UtRCOauWxpjXtyMRwX8uDG0+Urg/Qafp9ewEhn4+EoQpuwgYGh4+GXmZBv+RNYoxy8qJy8pp64oZxYlKmoVfl3Kondh3IXrC8pGVZQLjf9N5huVf5u5K0pk9rKYhZlLqizK+IJy+oJy5rxyun52uHKwI6fzecbTm3G3G0Kws6npbOi9C/hXJLy+l97+OHOgNR8zClP9ZR8FXDs7jtQJ7z99AT6eHKyc+1A11ls02J7X/Sqz7VH6s+vx9y9EXKvya6qFg4OaL4e+uBXd8yxt+F3mZG+eqF5UZkul2FjFf6kXHlVFLGH/ZwEL2l56LYwLhS8GDWS6SjkLAQv2nZ8o+9v8lYNV9kXjfxJwb0vim6bIuzWeVwqdz2fbX8qXXSvxuFEmOBgVcMfN5P6HaaMv0mbbcxa68nGc68qb7siZeHt6rDX9/dNT7ffCWy56366WNVW7NVW53z3r+/hiCOrglzdju1tSMV8y2VUIHaLonO3PmRvInRvIFrOoNxhOlfwlAaPGfV80050z2XFa1LNwXnQz9Iw6+GOAGtU8jqrgKehzpjcXpS3eYbY3dw5V9ceI7zbdlY3gWVXEC8Rn8fL593kLAxmLyYSxZrsyp96e7nkQ+/SC77USWWOx++UiOaYK6rMdL+a5XC0CLvltlP61Pi8uBLZeDX19JaTteiSCxosLwXcr3C9l29SlmuJ4Lc/hdonrwyq3lxc92m54DTwIHX0ao+zImH2TPP8OhstWdmUq34NDobILMs5QdmYpe3OVA3nKrtPKrnQxC51piOqh0OjOECJckLqUnrSF3hQxyu5kZKndl65EBjKQhb50ZK5/KeJD4UxP6nT7qQ+vooaehA48Dh5+Gj7xOmb2bYKyI23qdcL4ixhEic+GdAhZaMuYf5c+8eLUYHPkwP3It1f975a7NJy2LI0zzQk3ylgS8JKDk/2MknwFB4uBibEDVMwn6oWG9RFRwFEK/XA37RBXQcCY4VcFZS7y0b56QR5LAkYDAg71EGSsCk7iDKpt1NyRfkZCmRtggVnoYHG22cdElK7gXYWhqNu/FTAqYHEK+pNpZ9V0tJFo348ONoBuxUDDMjsNBI1wP8sQL1Nxm9VfyVilZKgXFyw9/FhqQ/PYeIV6WtQwal/UwfAxHqL2/auIrv3UwWL5Kx5VZbEwdy3MP1tCwO5OpioBYwEYE9EIyl9EFDDs6+5mpVDYeXnae3s7qOLj44jgPHzs7GxhYa6jr39SW/P4ieMHsFq8b/+OPXu37d23HQ4Wq16IEN5FNQzpGhnrGRrpwotQr7mFsYWlCRRrYm5iaWMJ6To4O7i6uSCOLo5Ork4wMc6jJkagYagaJj6pdeLQ0QMQsHg8pnYYwUNsy4KSoeGtOzfv3r1t3/5d6OX4icNqGmoI9luJooWA4XIEMsb2KzRQEKOBahtlN579HwU8P1A3/KYUIhFmj8v8zxUHVmV752MjdKpzaYYzilfIBlu0Op9mYbIaq8jYQT07eAZbuj7W02fF5capvgroWfkBUq8b7ynDdHf/6+yu5xmdz9JbHyQ9aYq9fykCU9DYVVSRgWlt7LJxrsmxu1qpQBqKXZsvhj1oCMSf2sGXudjjo3yPqVRRwJeEyhWanL8i5KNfF5Tw7pJ655VXVFlQXvmYJSt/fImg6r/IopIXZq+KmZ+5gixMf8yijwUHj9fBrP2tme0tac2N0Vj8vlEbfA+Lu/WRzRfjXzSlvLt/evB14XhHGQjMDJ4Ry9+5iXNzEw3KiQvKSWw+v7QAGU/XwFszwyVw+XBbQffznHcP0h9djmmqDUTEOrj13qlFB2cv1sFYfC3HTLJyHN9FxInlxePEWSUyKWRhohYR28JJ4TzK7jrlBF5SjUlmYQr6QwmiHEUNXaocKxMCDU9WKqerhUxW4lPNjZbMYW55rFyVeUxH/2VUT6EhPLXobLxWeLcRYfoXs46djxJfXMMGKMW5fMczp23rc10uFLpfLlFcr/J7dDH6ze1U7KPGNy1MVCr7S2dRnw2Wi43pzvyR1rSuRzEvrgfeP+f54Jwf3uRamfuNCu97Z4Me1AsaftoY0d2SPNSaOdm9KMW+7Jm+bJhYkHGfkE8EvGgaoTLOw0nxWfECwUAInkIWC+ilMnq4cG6kcAH19MfgPPSJLqZ7s2Z6smZ7UeQtdaTq69MzuEB1jfhJ5gdz5gezRAEr+wUBQ4QzbzOHHyW+uxry+Kz3g2rPm2VujSXOF/JsrxY63ihxuV3m+rTWo7XBu7MxqK8pbOB25Mj9WKT/dnTHzehXV8Jazvk3lbpeyLG5mGWNXMmzuVZoea/a4dUV787bIagph1piRl8koKPZtnQUmshMe/psRxqKV2VftvJ9zmxnymxnkpi5rhRkvjtVlQXotgcXp873JIuBbuf7kpCF3qT5nsSPSZ7rETLfh2dT5nvTEJV30RDc3JeO95lpOzX6Mmq4JbT3nt/75qDRZxFTL6Ln3yYp3yXPvEoYbYlE7Y6MvRSCglj85GMvTyH9D6OeX/YDn6pUm6xILGzjVgvjxaBhirXwlECz5CAztMWcCjRNCDBBon30l+JtGL0YQZaYLvY0DPLQw9wy9iRj9V0VUZBY8RUT4KEX6KmPoIHrhZd8TLCXgZgQb8MwX2H+WbCvrzmmdlFcBnuawIWi8HBU1aNieSoeVTr8WOwuLf1+uuj7qYDF8z4eRggKVpjyY/FqiU7xJthEjYYYVY2Lxl9V1X/RnYeRr8LEz9PU30vQMGQMJWNaW+Gs/1fB/DPiZq+tCpZ+VRHnn8WjvSUmmTVcHPTlzqZyZ3PZ4iYsCBhboBFbK10EAnZ1MnVzNZPLzD96187b2y4oyFWVxYduwUEefn6uhgZqOtrH1E7sPyJId+uRo3tOqh86qX4E1TCib6BpY2tm72Atc3Nykzs7OdmhofB0c3d3xUlLG3Nre0uo10Xm7OPvExgSgPgG+AaFBvgF+Xh6K+QKuaePu5evh7uXm6vcCbF1sMKrcLR1sHBxs0fQcHCxsXO0tLIzs7A2huahdnSE7vBCRObubGVrgZLazsHWCv9CA10E7re0s7J1srN2sLFzcUDD1MrsfxQwllqxt6LtQebDK3G1BZ6igDNj7AqSnQtTnGpyPRrPBL+8ndL1LHekrXSp2P3vBAzpws3zw9jVUofMD5+ZHazC9h+sTWLvz9tHSS3Xo2vyXLBFNjVEPz3CODlYLzFIG9tSStJssXsWu1Qulrrj7yz+RguroR0V6Es5tViGzl5UIvOXhEDAYi370cTKJeNeWlAiKvui8d+VwqpXofE/VMB/ORd9YW6kFv+03pfZbx6mPrlx6v7FuAeXTj2/efre+djHl5Ne3cpoe5A9+LoYHxi7n1QCnh4/N4u7vCYaFsbF1AlLrTPVsyOloz2F2B4FmL3P8lrvwsFxTTXByN3zYU+uxbbeS+p5mjn8Nn9xPVjYiqUcOy/cMzZev5SJeqUq8Pp47ZJ6xZOTWPM+JwgbC8MfqrFCjCXb2eEiMUIZrZrHxtQ0ZqRRH4+WY1V4dmQpC2NVyPz4X2d2rHJ+dCniNVgzRpRj+JCVWJrFviTMGGOLDXYp1+Y4V6TbY3t2fYEcM+3YVNV8Kfr1ndSOR5nYNY01bCWmBLCm+L4CR6yPTnUUYDVx9G3mwLNUrEG8vB5xt9b/aonHhTzZreqAa6Ve5/JcYfRbtb7ProcvabgLK7u5WJ1FxIpz8bhUBIuiFe2Lo2hisfFXAhZmsD+R7qdW/n8VsKoXsaNPfYz5WNgOWRiAegX7wn+wy/y702NPk7pvRTyt87lfpbhRIruc59CQZYtjY5FTU4nT83qPd5e8e24EDdwJHXkQOdEShww9jO69F9dxK+7tjejnl0JwZUO2dV26WW2acUHY8epEnauFtvdr5K+vBLQ2+nfeDf/wInnsVcpM22lk7HXiRwGjJs6ZbktCVTrTkYjjdFcSgjpVFdGjolCX5CoqVnBwimBceLc7aVZICiK+w0Lf6b+MUBAvCfhd0uiLmKEn4V23fHvvBQw9Dht7EjXzKhFV7/yblKGH4cOPY/ClAXn/JGbwaex4a+pseya+NGD2e+T5qc470Q/rfPFNDvfmQcDCSvmibuFdJCUYf0wsxSSFmCPY4ZgYZBHtbYzAuKpE+GBXpjAhjJIUu5GxDxlLp6p8qkZRkPAobKpSKRqCX33MwvwsIwKtsY8JiQrGLmJb2BdGFBdoA9xNsC9ajK8MtwDpi1GdRAPXCFGY/lUW13fNxBndTwUsVpl+nuYIlmbFChWFqWhN8U1EK+MIm6oifiS87ZLCF/c5LxXTcmNvubGPu4mvhxmOCB4uxhTTyJ/Gy80EwfSyKgpXY1VkDrpiXO10nOx0ERcHQ1dHI9hXJWA4GHGwM0TEyWeh/JVbu7uLsXR3t4yK8goNlfv5O3p52ULAvr5OCg8nRwdzVMCqQL1GuJEJe6qtDKBeTa3junrq5haGLq4O0KGzi72lFea07WBfD4UMD+FReycbFzdHNw9XmBLSRbz9PJcE7OMuV8jwlI+/FwKPQsC4zDfQG0c3BfwqR9BA3L3wDnKfAAXeH92hC08vQd64GIG/Pbw8gkKDYHdoGMoX4uqIuHnKPXwUci93R5nTz+YGqhcGa4TVX9UU9AgmkBvG28qwA+jlreTrNSFXqkOwt6goTY7babC/tyRNjrtBLpUFYW341Z3TuP13rLMGy72YcBaK3ZH6yd5KVZRjF1D+4jzEiV24MPH8MDRcu7gJqHy4LQ8CQzGNLV0pwaZRXgaRnvpBrieD3dTi/XTSI4TNlnWFMmyGbG/O6n1aMNmFHaoN8x/qlcrryunzStgUxSiUOY/1YMzrXhQeioFK8ex/k6vKhStK5eIRDVVEkc/j3YQZ5vnJepSnyNxEHdqIcgqmbECnWM3FCu7scM1Ie/Fod2XX8wLczXz/QuK9hsSWxoxbdfHNV1Je38UaMPbEnpnqrsaiNf75mHmen25YmLkwN3V+XvicixX81CWsBy9+4IvKCWHtHPvXpvvqJzpqep8WddzPfnI5/n59FO6KuV0X9vBizLPrSa13T7+9l4FNp5NdVXhn4b8dvtngv50g4/PKD4CMdfdSYUcSSmQoELuxsAlrDMLGFyBhc69yqgFbuobeZilHqucHK7CZWfkBVM8oh6vwUDlaK2T8LPZzCWdGloJNXmhj39ZkXzEsjja2gI11F+IhnsJ59IK2uLELT6EL7Cseep3b2ZyOra03zwTgvh18x8qJs8yJtcYxL1a44Qf3BaEIxgWjb4ErDzuSpvuwXwljUogSGanFRmWsPmAfELYLYdPQg3NB18X0XfYAAEAASURBVMu9qjMcsD6KG3tww8+5HNnlQs97Z0NeXovHZqLex8kfWrOgbWS8LXNxLVaYE16cFhaWY9EYb88YfZuGYBZ6qhPXCFHNJKMBbase4mK8BA/FmWo08FB8CRpixOlolfI/fQdMUyO4YE4IVkCFKLFijSxOfUOHE69S3j+K6bkb/fJiyMPagBtFnheyZJey3RoLPG5XeD2o8X5c59naGNh+M6TnXvj484TJl4mLs8rpH56mvG9O7rod234jqrlGcadchvK3JsmoJEq3OsHsYqZ9U7EMc9dPz/t03Iwce5E23JI03Zql7MzDerAw047p6L5MYXq5T1jKnW5LmXqXPN+bMduXMdObPt2dphzOXcp7VO2Zc/2nETwrXoBrFi/LmO3KwMruTM9SPl33FVe7p7sz8G7IrBjMNr9LHm9N7LwT0HU3sO9h6PuHEW8bvfFPG3oUNfQopv1GIGr3vgeRwDL8JH7kaaKY3ntR75sTe+6fetkYeT7POSfGDNs5o7208DMDp/xNkvzMENwqmRhgLpo4XK6JGzdw52RigCXu9AuRGQTJjJBAma6/i6aXo5qH/XF3h4+xV8MtueJdudgbhQlhHzluxtXCLUCY3cUSLMQGgQV6mMKjCBowGc6I1Wd8OG6EdcKiqTh5i/lY7BaGNVEaqorCT8tEb2cDT6el4hKKxcouLkOtKV6sutLLFYu+wrNiuSlz0EawuUnupA8p4kZbWBDTvIjY8PeyCPa1Dvm4Z0q1c0o1PyxeKbrTw8VIFXdnY5m9PoI9U+6uJnI8dDJE8Yq2h8zUU27u5W6BoIGHiPgQl9lZadpaaiF2VtqIs52Bo40ejh6u5gqZlYerJY7uLlgMdlDIbFydLLDnWeZsKW5+xg4s7H/GGTzELLTM1cLNzVLM4rQzZp6FyOVW7u62MhcHKwszEyMDEyM97NUyMdFQ1zyob6gGATu7WJvjxmJrQ1s7c3sHSxdXSHEp7h4wsa2ltbGJqZ6TzE7mYW9lZ2LnZOoit3ZT2Hn6OvsEuHv7e6giWlY84qRvoGdAsHdgiI+vn4eXt5uHwsUNO8J85Z4QtIezzM0B9lXFwRlFrgU0j4a3nzei8PWEceFaGFeULuyrys9ws2bfi8yRdwUTXaWjHUWIeEMn/m4+a4zFYiR2S2HOOe+UQ3qMTXK4VXqEcLNN1Wmf+oLAGzXRt8/FPb6a/PruaWw4Ut36grXeT4ObYYbbirAgiuDeGKGEHT0nChj3eEDAtxoizpcE5cS5RHmaRGFTn6MOlmFC3TVDZMdxnyhuFC5Ktrl7LupJ46nW+xkdLVndL7NHukoG2wuE3UwouwWfXYHXxV3ceAoRqmSxUFYpGQ2xaFbVzZDunJgLi6uzwhrt/PiZ9125r1viscSrnIHYYKPFYCJ3ul45eW7+Qw3s2/Y0HUu/LTcTr9eFYv9zRYYcv1KCNfKzuX71Bf4NJX4Xy3xxw2578+mBV/n4OjI9fHZm7KwwBT15Qam8qVzAxjGsNCPXlTPYbn1VOXNdOXVdOX5VOXxpvr9hsv3s0Mvyrubc103p+LffOBOGe17v1EXfb4gTp7g7H+eivMZEBd4cW71AFUsACG6SEe4O6szD7tP5wTI4FVLExAPcPPQmB7fT4DYbeG6wNRs31Yh31+AluOUGR1hztKNg4HVmW/OpkTYs8Av33uAkXIgGrlGOQPnVeDnuw8EFeMPBd7lvmhNeP4jtep7W0hR677Lf01sR2DU22JqL+4Y7HqRhFD1siLhc7IObgE8F6qWEmyFpYSYZYSalifa43ehxQ8ybm0nvX2ZhGhnviQ8g2hffLebfn5nrq8QtRtMdpZNtJb2P0yFgLABjI1JpkhW2AacF6SX5aeeEmxREWZQm2NZmODZV+mArEyar75/z7nl8qv9pEjbcjqG+XMx4W/Zkew6sjO1XmNxG0FA9C0eqApXCrGOtqUNYenyeMPIqaRy2bssQzT38Gh/4lKhwHMfa0nEeShZfLrpZPD677tN6O6izObLvadx0B+4rEzLVfhpvNfEufeqtkIk3ae9b4tpvB7+44o/J58u5LjVJDqXRVpVxtmg0ZDleyXdqrvN+fimg/Vb4wOM42HqqNWW2LXWhIxNz1xMvMxY1nNh1O/r1laD71W5wcFW8aWWsRXm0SVW8MbYs4czdCreXlwKg4eGWFDh4+s1pYS666zTeZ+ZdEo7I1NvUiTcp2CcFa2KqfGEoD0csqOMhnDrbm6lS7Fhbsiqj71KQsbZUVSY70lWZ6kqb7ExFxttTxjuSkAm89k0iNmENPo/pfhDW1uT/7KK8+azjhUy9c2nazTVOz88rXl/1e3nJ58l5j8d1crRRxItpvRqMrxqtjREP6wIh4II4s0R/7XD345EKLdweGe2ugx1V4vqucMOkQgu/PRDkrIb13RBXbdyaH+Ck7+9sGOAi7GrGZmYfFw04WOH0X8ENu6iDxVt1sSVKXJTFiizqRdhUdFiwwsJPZoygIZ5E6YkaFDfh4CHEienZjyu1RngIp3o44rcyBNd+KlcIWHDw4u9afCpguFa0r/CUs5HCyRDxcNRfmvh11MG+YjcHA0crLQdLTWdbXScbHRw/NrRRd8LNMDS0LbPT8Xe3wGvFN1l6KxcTj4+BdFXxcBZWamX2htCnva2eg52+GEwOu7tZeHpYiVG4W2KuGEEDm6fMjE9qqO3R0Tqor3PY2PAEHtrbGKCuFVd25U6WmI7Fz26g4SW383C1hmghXdx9JG57NjFSRxtn5K7WXh4ObjJrOFjUsLj6Kx7lbjYyVxt7W2tTIzNjA2P8SIexkTZ2SmtqHzUw0kD5a++I+V4zBycLeBdShClV+ahJG0ga6nWS2cC+Mg9bV3cbHOVeDu7ejt7+clHAonc9fdwQlYnR9vCWwbuuMnsnZxs7ewtoHke0oXYU1qqYW5kYGOsamuiZWRpjXRnzz5h2RtWLOWcXVOE+CvjY099blZ81XwnGNp+Oxym4F6L9UTLS2ZyK4E6Pu/XBWJqF/DKiTZPCTGMDDKN9DbDTDxv3hd+0SpXDOlWZ7mdy3LGx+cZZ/5vnAu5eCL5/OezV3UQxL++cws3EWOhtbozEedzX9OZhcvfzrMF3+aNdRR86Czqfnm65HluW6YSbcKqz/XJi5dE+1r6Oum4WJzytT8otDnpYHfJzOhbhronf4Tqbp7hRG3rvSvS9q+FXaz1Ls0wvVLlC7ViExvu8vn8KE8II9IygSkZmFzMzWq/KSF8FMjpQNT5Ug0wOItUT7yuRsYGKsYEyBHubXz6MxcYoNN635cIxCIp1fGB8Y8BN0tj53Hw94nK19/kyRUGaXVaCTVyAfqi7erhCJ97XAPdrYaX8bL47bobG8jC2VvW8yhvqKhnrr0J3U1gmn7w81FOJG5NwO9PEQM3UYN38yPm5YXwpuaAcvaocu6YcujTbXYf7XHE3ZOvNtOZLsVfLcTekW02WDJtjsUUWs7iXy71eNCVhwRhT1n3Pc6H54TfFwg3BHUXtjxNf3olovR+NO3fFe3bhTlgNboPh4E7cmwt3QpNowMSiaKFYBFZ+ciP09b0YXCwKG7qFgwX7Dp/BEdfgHfAsXoV3w5u8e4hNZzFYpW69H9v7PB3nEQi493nWuwepmD+/XRdyodgb9/KmhhqfjrZCcFt5dpRFzWlsqgp+dS25pznzo4Bz8IE/ClgoglH+YhIb987i9z16n2Z0PEx6eTP68eUILCHjxzQK4iyyI4zSArQzgnTxK2lFsWYX8l2ulsqxVAwHv7kd3dWcgBtdcOuLGAhYuEmmMwcblUXvinuVURYjYqkqFr7/vwQsmhgaRj2NQMaIWFu/uxfS9TgKtv7wJhXGVUkXXkcwmyqm827okwvud6pdsI5bk2JVHGmWHaCfE2RYEG5cHm9yJtm0qcz5Qa37mxshPQ+iR58nTrxKnH6bjAXdmbfC+rGo4f4HcaiSm2vdbhTbX8a9v0mWZdH6xZFaVQn6Vad069NNrhc6oEp+dy1s4OEplMJjL5I+PIsfaokceBSOpdaJVwmwr+DgtmQUrPCucjh/pi8TEdWLk7CpKFTY9P+7gPGSxQp4qQj+VMAjz+Ph4OdXFA9qHS7nGV/IMoJ0X13xfdrg1VKveFAju1flguBbhZhX+Pm2axEvLofeq/G/VqbAREhaqD5+ZiBScTJSoRHtoYUkB5ng/4YRHur45TX8pkeCvz42YcV6GQpbmmV6QW5Y0zXCDbjBCn38Ko6PTN1HhuNS/OTaWOUVF3TxMxrCFio/U8wwC0Ut7mr1soSDIUgIFRFNCdeq3AyPisYVDSpqGG3RsjiK58UjXi5GZWtcAEmLE87iEe5URVS4u7MgVwgY9rU2P2ljoY4C1N5aC0EDVoaPUcXiAicbLSuTo5gNtjNXc7bVRuDmxeC+IAOIFnG211MFxauTraGthY6x3jFD/WOiTS3MNLGICac62hstBnLVt7PRQawstOFOGFRb8wACB+tpH1rMEdzgi1uMEPzQFQpcNKBb7LeyttTDGTzUUj+oobZP7dieE0d362getTDVtbU0dLQzwzYrFxdLaBhByevhYSfG1c3WwdHGzMxMX8/YDGun+J+5kZm5gZ6+hqGRNuacrW1MYUQHJytRwFj0/RhXVK5wJxaGUQGbWenbOZlb2ho74quAmy1k7OBiZY8blN3tVBEXesUjymU3haPc08nD28XLx9XT28Xdw1Emt4PvnfDFws12sQK2W9QwTGyL6Ws4WFtPU0dfy9jMGBu7nNycbRxtreytcbTHsrQP5r7lqvysNMWgLtf6erX7gwb/F01Ri4nB7xE+vx7bVO1bl+2al2CZEKgX46+HX3EKVeA+ueOhcm3M9uCG4OwYm7J0V6wHQ8DXa/2a6v1vNwTduxjy+FrUpxHti/MProSj3XwtvPlaaMeTVGxfgpuv1wZUZLtCwGUZHriHL8bXystOy9nkCOJqctTV9LC7xRH8kCS+1WKxJyfepipHVlsky08xPRV6vCrPBm+CSvT1/aThdyUfOsqQ4cVM9tcg0JuYsfc1yOjAmQ/91ThODNVNfzg3M4LUiRnuLhvuLhHT9yZ34G0eKuyhDtxHJNwbjWCjmfgLGNhHhlp/qL0U9/g23ziFu3jPlQVjfj4tSrgfMS3cOjvaLj/JviTdCQLGnUW4+aoV32meZw+2lYz1VEG63a/z7l+PbLoY9PR2fPP1KDyLm5EG3pQMtZdP9dbND16EgKe6z35oLe1pyWm9lXSnPhQ/gJUfjx8g08aPXgm/exVrXJpiAw3jVymwjIo1Y6TtYUbH4wwsFeMHJhclGjXSliP+egZ8CbOitBULXxxxBke4Eyf7XmagDZWKeoY+0RZFC9eKwcuhQzgYhbIYyBhixnlMGot6xkOUyMqxegTFK345BN8JOh9nPbwYda0qCL+MhrvJsY8PKUy0R65XhT6+lNB2+3TvI8wYL05B9xShfP9UwJiCXhiowg9ZiD+UgfvQhlvz8Ptc7+6hto6/VuHbUCDHZpySBLOCaEMcq9NsURjhhmPhbqU7cZiOHnubM9dbJAZ3pioHypRDZbgNCfcd/fUNSNgCjQwWI+IU9EJvHgJromyd78lV9gk3NcHTqG5VllVJFwIWq2FRvaiGcSVOikEBjaCkxnImFmI/vE5BVT36UgjK3zc3Au7XOl0ptMQi7pkky6IIkyx/vXQf7exA3aJIvbI4/epkg8Yiu+Z6j7dNwUMtcSNP40RlYoPS9BtRwzBxBjYotTUFolh81uB/Oce2NtkYgX0r4rRrkgwuZllipzQ2eb1pDEMp3HUnsuNW6LsbAa3XvLHaChmPtyZPv0vra4kafBU33pk625813XsaQeELgy5VsShk21NUpTB2ok13ZyJoqPLpsrewIo5l70HsccM90/kIJqunO9MWNZw825GBTrHQ23Uv/G6lY9uNYNj31WX/lnov/BNeXQrGR31wxkOVxU8e3doY1Vwf1FTpd6XUuyzFHpNkmFxB8PNqSG6c8KMFcb74vYHjmGtJDhYdbCBsvMKdwb7mCJZ+Q72wG1kPxv002EUV6mMkBvbFTUS4mygmRLgnR6xxsfgqs9NytFRD0MC0MEwMcUKl8CiOaOOMysriT1WIS7Y4Qr24RhTwp6JFW3wtLCteDKkjPm74SUg8JUR8lUJmuLjailJVf3FzkzBRjHlgccYY5SyqW283cx+5hWpuGQ2haBbjsKReUcBw9scI9sU+KRxN9I+jkIVfRe+inIV6Uexiq5Srs7GLE0wMHxssbqHSh1D1tI8Y6B7X1jgEoR47vPPQ/q3wKxyM4Ieu4F1DvRNimQsZW5hqw9n/D2fv2dVWtm1r19+67W33nnNqV5UzOecoEMoRCRAig8hZRBFEzjnnjDE4YRsbZ5xTuVw532dp2dreJ9wPb7XeZk0thLSQbfrsY/QxBjZhnuZ14R+e57+EgGmGJbai/Fhx5KJhCpA+IQluUyhl8fHS2BhpaEh0aEhkaGgwxT+YnPFAQcaYnAEZX41WodUpWdUauQi8V7AvJA0BY5vCPCVJQqHGiy4qNpKkKIgZyFRxAF8VUGikQK6Oh6EzcswFxZnpViPUazKroV6kNoJbzD2TdXaDO4F6w6NCouMjo2KjKDiOlsRwYEhUSCWyhAR5okynVBo1bnzx4noT9bVPLte/udX2Cc43t5wvr7fdpwJ4tnS6w9Jl1zRXKCsLEqh1ayxSOauT++tTibjOdefSs4nQ6O3tRmp5b+/UIHnhVJgYumWDDoaSkcUiEMEQMJqYpwnx261KGn1cW68mBL05U7w0YlscKh7rzK8r1OQYwlMVAehgizIkQxNOp0abKQKfRW+DmWYXu7Nlu3Mlz496f3g68eurmd/fzP/9Hu24JsRvP6z+8X7xt7fzrAhKEULR8H+Ln9YRowJ+XPnrh+U/f5gX8fObCZxThHYJpBM/d+OnpyO/vhwnoUtV1fsno989nXxxb/TWpY7NmdoRZ3Z/a+b8UPlkZ8FUZ97yaAlNtR5f6xYLgimDph765xdTNCqBaOnd8fy45+4Vx8FyCfR876CZmqWH11ofX297frPzNU1F7g9i4ELXPr/pPLnWcnm5aK7POOxQ9NUnDjpUHTXxtCLqrJXSa2yqO2193HZ11X6020TW+c29gZd3uugEiXiFfVGTdKoS4FK3sCNMCV8iagHcCcS9+ARWMRwN0Qr4dhLyo7UTnS7Y/xMuP53oqoMgBbzHRvAv+JOytBfjRMjfHPcdbdVhDp/ryxpqNQ+3pgloS6GN2spQHm0ab63ZOWRAq0I10Sv6Y1AThZOA7C9mbLic/STmLPxcgJsRWk09H/n+4SCNk6Dhm2uVgi2rxzThUI1QG1qTyDrrNJInvjyTe7RS9PwKFS/tPz/qoNvDn8/7wN/YyN9CwIN/UwEMXvd/hFgNLK6vev5+3SvClbsVM7j/sv7+lNf8F4jPhKqBSN5/fyCVLpA95C3W14or3ygEtB86YGJY+e2t2sf7RTdXctZ6hJjzdJNhvFY33Zg8WCHrKY2CgDf69VdnrHfX859frkC5wru/PWr680kTRioXWmEyoTb3eQdOpW+P7G9v2J8d4MzKvzhq2hzUrfao59qk822KnaHU3WHrwUQmIvLRTsWDrZKnl8p58t/PugS86BbwDiM6iQChXAozueAqf9kBuYq0irNMsK29ckF0j4ufmOvj4oDihpjh/ugt/5aPHQgE/OeLDjf4ZPhAOIW8OawS2ff6TOr+WPLRYsHBaNbuoOXyWDYr+8PpvJtzBTdmc1lvL5ccr1ffWKreGM4faTZ2VCkJrkDAjqKE3loNqgAMOUyDzYbxNnNnpZKO9CSJhRYcuUkVufLKPAWAhkX71cf2F1aaMsajet0drMoKFOVFqqoyXW1FcmGuoiCLJGsSpiStPFAtCyARm6wNN6rDWFMNRH2jocbMVAneJYxRrMX52spiEyAjyxW+lG4mLRonOpvEPd/CM3lZ0ffEa4YG/AcvxZP5Ft7R1UiZVo5CNa2YtRXWDEVOhgqQhbVahGhwplWdlaHJtCjzs7UVxWmgIEfnehrPVGRb5SCdsHmmkgxuihG2liLVMtIUZkOcOTkepJikmKFEiNFj6DYtRYE3yn3d5ZYiUyvYlQEPIWZoGE6ljbMsMSohLowyWklsqKho9RpeU2XSk/Ql7Cwl++uCktAsT46LFszM2KmIJMtlMcDVfEMC6aKDqQCm9peCYHOqKtWiw+ik0ugSElXRMTJ//whPrwBPbx+6Z8QnxlEvROVPeFQYlBwXHwMgZgqCKT2SJMTJFUmJiXFu4GcmRIxCpY3zZ4iIjg+HiWFcVp1RqdLJ4GD2EDByWQSkq9FKRdIl3+xGZIS/t9epM6f/7fy5ryiC4t2pDOZYQBUTfT8AdwgTC+VJgb7nvS8EhAX5Bvl9ffYbDz/PL/54MfrXy7HXN1thX1rhCHjQ/8MDfjfNP7vixASErZdfl71NKW12o6OCJoum3nrLRHvOQn/h1cXGRwe9T671fXg4gWVaME4/HqKQBj1Kve/3T0df3+uhTunZUQcXWcXNq+Nurr+800M2l5wurbJuXWy4sdN4uN10Za1+ebyU97IXJlHeTl+3Ygug0xtN+OIJfXfbTROdmVuTJVDO6+PhDyfjtNyC2/Au/f0d3T+W2PzxbgEC/hx//bAK/v4Rhl77G9IVePczSqak+BMHY07++wdeYYaaZrKq2MpgYjd+e0VQFLfaMkwP+74/mTo5Griy2Xx5vXVvybEwWjXqLBhpzRltyZjrs11cqLmxQWB/9K83K3+/W+auOChwXOCG6UwiggOEuKF9GNwM71L6JRinn0/8+nISvv/uUf+393tf3emgEomGjpfmC6Z6jEMtalziQw79aKuJ3zL412Z7spl+wXwLfOnQObFfOBg5C/XSOdIFISyMQoV9Rd5lw8P/is8FLh6o/56ARa79H6hXZGII+LfnGOkHOVK4TN321VHbZHdGf0sKGHSYJjutNHM+2mx6eKnt+aHzze32Hx53CU0iBQcZ2lro6uWm3t9e0PSxH3c0EGkYdoeD6Yd1st90tF6BM2t3ImttwDLh0I02IIjl0DA1x9sjlhtLBfe2y15er/vu2PErrScgYJF3P19FDv6cgD+xLxz8/5uAIV2Bwl9BOV0CVZ+0uzn4cwKGht8f1z+7Una0lnswYV3vSYWABysUUw3GsVoVHSfm21RXpmFfG5z67mbd5wT85/OWv160uiC0wvjjKUwsUDImZygN5/P9TduNhYzdEQzSiqmmpFmHer7VsNAGzesuT2Zcn8t+uF365rr9rxMXAdOygw/hNQ1MusRSLrGa6z8VU8HE/yRgfsD/NwELQQWh9Ou/Ad9LAfdJOyGBb2/V35i3XJ5M3h5UrXYpFls1YzVJg+Xx47Wy6XrVbJNq3qFZatOudRm3elM4Q+yN5eyM5pPFgHHJaPwnAuYfBREX+sqNtZpoZSro43yaegpFui7ns1TsKEmuF/NzenKoG1iuPjVkjszLkuRmxudkxGWnAwmkSPgXroV0dYogkYANqhAImL3IwdAqT4Nioc+SAl1FkbHMpodc3d/LM9mLdAv78kz22KZEdod6Y8JPi6zMK3AduqWXMjRcmKMRCRgqzeQFXX6oTKsyK0NFLjY7U5uXo2flOtRbmGuAnkXe5ckZFqk1NdFilrC67FSK7HR1boYWwNxQOCDLiwkZGxS8+/8kYLlA1SbYVKpVxQLByaxJoDOVFvWpSBAB3Rp1MqhXq0oQ95AuWV4XNGlmDcQMK9Prii5X9LoymVSAjUEvhX3F+LMYjjalKNGdWIjpmiGV6yWJhliJLjJKGhkdH58giZPEh0WEB4WEQHLh8FwUvbEi2bioN1GjUWm1ajf7siE169KmEYxSgIndIGsL+1JfxAoBI47ZQ8OEqQlQQ8MJsmi1JhGTV5I8JlEaxd6NpKToiHA/H+/TF85/Q9MPqpBp+hEXHyUqYE4GgDIk7tAv2B/SDQoPZnPqwmnvAJ8v/sYS9W4ai+l3d7s+J+AfH47c3arfmy7eGC2kp/GIM3OgLWOgJbOnjkBi6qQzd2eqdm+65ua64/nh4HcPxj88GsGXSwQYBQbF0huLTljQ8NsHdKkcEAEBw8f0jWLMw+u7ffTGotMWeHrU9fimEzw67Hh0s2t/rXpl0rY8XtzXnNpWZWwu0zcU6eoKFLRZ/uTBzqbm58lh35PDnrf3h2mB+eOT8V+eT/36Yvq3lzPwMVTHCtv9/FrA7x8WwJ/fL4J/IeMf1v4GP66I3bv++rD41/fzACM3li43DcPEH8n4xRgcLPQV+W75+2dT3z6euHeta3uhcm6kcHG8crQrv6lCS3M7lDr1WqNOUuP5GKTf3yeLOfnh0dj3j8exN//6YhaPFfjt5Rz4g06Zb+b/ejsH/ng9A1zdxLCOL9KSjObPxL0pPcIlR5KePs8bUzkLgxn071wYyCEB32PXCxFvu36uN2dhIGt9In9voYQYg5Brv9P29qGQ6BUBH8PBxJORuXCwyHBuuhWZGFZ2MzTPQfgS+6XjMeFfmNgNsYWyYFEGojL+V/krcPDbKeYpkZmmRfDnCpj216C30cCwrKX+HJTx4UrN8U4dkRisy4jg318OYh/74aQDHxm9JCkL/u15LwXBQAggQ8/EkN8Ip8bfn41xWHx9s/3FleZHu7XYYjHmrA1kzranDNUphIh0deKUQ0X3D3qA3Nmw0Vfr7a0GGh/+/AgnVOdfLxC4n7TvfyVgqOgT3A2h2HxOxv9J/vLwvypgDM+/PsVv1fzDg8Y/nrajU8VOUjTf+PkxQWl+6nri24jgF9eqIOCrM9nbA+nzLckjNcqF1pQ5hwFBvNlvhilRqzQIg6g+J2B38S6FvH88c4j47aTxp4d139+tJcP64mo5GhcpfDBhWerQT9Spx+3KMbtsoiFpvk2z0qWD8h9ul2Pj+vluC11Q/n7RKxwXXM5t9/ovmp44/Mtu4WzhDhIQSwCuz1DsBSauH4nZFdj/9FKCmBZjA6zCG510/vqo/af7rT/ea3myW0oO++Z8xuUJy05/+lKrabZRt9xmnmnQTtdrxuvkpMMX2rUrnQbOKJsDGXQHG27Q05VT6FRfEl9XEAUNMzYGTTzZnjrXk7E8mL06nItnotuu4jrNsEoyoooy4lxx5kSqdcvylJQPuetlxQ1lRSJKbKrifGVRnqKQRpL5UKDKxYj4ifA9hYlM7KZbviSyr1sB27KVovaFOCnaERK3hhiezxOAK5Ub6/4WUQfzfNhX5GNWAS72xepckm9wE7DArOlKUf5a0pIwTKFKoWFIFHVrMSVZhU08vOumXhOlQcmErKO5zlcz09Q5Vl1epkHgbKtakLMuTqUvFWwKsEqhVuFLC+6nZIUbaGJR+BKdJqr80cCslxt1CpNejdnI5TdS4lYWoZJLIGaRgyFdNywpWmuqLjVFQ3Mrg16RYtICSoyQv6he5C+uK5chS0lKGK+TxqhXGswKXZpcY1Xrs2VKs0xl0BiNQKpUJkhlMoVcqVEnyWVy6FKtFqkX9gXJyQY3UMzwIn026LZBjtYNEreUJ+GRhn2p8TWYSQ9rSQOTAyYEjXUrUR4jyl+ErzQpGjXsBv0y+UE4TCQmRCG7oV4C48KKHyspgfLfuIRY9ohgqBcRfM7rPDTMShz9C5otYzElCk2lx2ch6M43N7tP9luvLVXx9xi9MtBqgYAH23NgRCb2DDssO9PV68NF+3NVzw/7390dQboh2uhGCfWSjhWpF6WL9hUhCl9WOmFBwA+utlBDDHdSv/TTq8nvn4+8fzr49lEffqWb+/b99fKD9RqGJUz3Fcz0l4x25NXbBAN2e5W+pz552JG6OlJ0edl+a7uZGO/JIRN7emjQD8P9/BTSWvjj7dLPz2mEOfXjSwG/v8PitAh+/7AE/qTa5/tlQRN//xF/fVgGOKFECOT3fuHPb6memuMncgM6+fZ+P4cMQbY+m377cOz2fhsHheHOrKGunN62zI5Ga41NUWuTtVRqRzqsiGCU+pNrXT+eTFNW9OZ4ABqGg8nvQsOwL3fLoAWODrCvwLsi6DSCKP92mgoxkX2hXriTZO3tvRp6hwmFYWM0qS8fb7dCvc4KdWeVAU9cf0MyrEaTMsq66C92fKmBs867e4IfyoUOEr2CLBYImFDzyCf2neCN3BCd8OJKpPfnp0M0W2a8AW5kEb+/HAV8SdwIBWz/Ld5O/XQy/PKo885uHfW+WNJIZDSWSDvr9QBTPeFogtIXp0v5O3Z7qxYCfnvb8ePjrt+e4cPvolHwh/tkCgXeBXAwgIz/fM7vfSTs0F/Ph/9+McL604PuH+51vr7R/ORA4OD9qcL1wazZdhMimFaFw7VJYw2CFL40aT1czL27VfTscs2LazXf3YWuuv+VgD8WBQmB09cQjCvESnfGlz0iAYvtGP8HAkbgCuA1ecLndOUyXjV/dxcrdQ3s6yZgkZjhYELQLgJu4a6OVm10vIKAqUGabzGvdFgW2kyYormICxoti6J9fb2SZhQ/36/Huvznk4bv71W68cP9qp8e1lLL+7Gc97HQ3xGLNQxHd0/4G3aHuhbajPi8yDRPNyugYXpYXhrLuLtWdHIRN5b9/Z1mfhAc4B8N4a7Mrhgx/uslPxr0Kayuz+dTlN6tgF058o+RZ7Gz2Kf+YkKx1nPMXEIom2OHmBFndd1eK4VYvz5qfbFfThT6zrJQc/VPBVxD3pp7Nk02aUfr5D1lsX2uZD9xDgZMDTToumrVbVUQsNReEMcK0Q43JU850xiZRf3eylCOSMDYR6ry4mzp4a7uGRQRCQP7XCW8QvdjNzBbufe2bHlRnqrMRlBXTzzZTcBwJEJWpOHPVaygWTMgXQ18WWYzVhangOI8vTiPj6QsuVv8yVlpUgqBWOkSxZN5AuTK81mrS9PYcBHwUjyNhzyBh7yIi4CVUC8g+4tnKlESGBvtHRRwSpYYhhhVuWqB1LJwoJSGEmSGjIk2w8oYm6nEFWuEKMbFk0xFUEaqKsMC+yqQvK5vj8EkJeJ/ImD4GO0L+6oUUTRwFltZwa96tYwgcYpRl0ZfqU/sCytzHQIWpw0ied1AEMPBGJvhLXjTaKDNpECgTGJAE8PKfAlWQxbDyliOlQaeYdEYs7TJ2TpTjlyTKtcm61LSIOBEuUKSmCRTKDXErJOk2LO0wn8C9er0GqA3aIHRqAdQL0QII7qbXomtr+jOIRQHW5MhXQiYNS3DhPMZ+SuCvC/ZX3zU2K9gYuxXbnCTmRnJWZmmVLMOIxiJZ1LRQk5awV3RqYPDQRJMLDS5jAz1Dw0gExwVHw0Ho4O/eH/c9eKa495O9Y2V4kd7dtqyfzjueXm19d2N7kcXm5nphvOW3pMtVUqm6VXZhOF6+IyEBHBv3nSHlQTwna1mmhlh/2Egzy8vxgiZ0gHqxa0OHLB0eCbHScMsek8SGmWFFdBnJIDFNDA1SPAZniZ80SK+fTKAi+r7ZxMEeB8fDlxZbV4dLV8aLh9yZBL9Xh4sxYBN1xtHSdJIU8rGaDH1OZxzMQlfXqy6sV5PB4ynhz2vjgZ+eDrz7FbPw+tO6nQBCWPA5s2D4ReMjng0+tvbxT/frzw96iEAfny55eRW97vHw4DOzG8fDArJ2nsDnBLwEHG2IDhMQdGLW12AmOrzG90Ez69u1G7MlM4O2zrqTa12U3Otua0hnWbr1UXKlmrjaEfO5lQNZVqPr/bSHfrhfgetObi3Fzf77l5qeXi1g0ae3CFhAPHtiELD60QIxJQzcW+xfAuP990D+92DGpxrFxcKmDRFLHdjohSMOq1MTyIvTkyity67x56JjdxZrqdl98ZI6bXluuPdZoqnxYZcwgAlIekrsC94dexADX/7oJustpCsPRlmtiDmJvqO4YEXS9FYuUIPMrQsPcgIKTOIkOIiVkYIcxH8+myUlYd8O8/ndUTwXdQgwaxYoBd6M4YcRszP9qJE0Fgqp6TNWaPh7xU+LEb13dtueHG18WS/Gir9+WHPTw87f37URXN/wPwAMrhcYU/0+I8nQrPon+6jmTp+fdj1xwmUPPDdcesP95z08Wdix/Fm9c2VKiYsTTqMvZVJXWUJdO0fqFGMNihnnVrc0YfLefe2Sx7vl7zCynS3gdgvNAAFIkn/ftf191u6GVMUK8Z128Wsqli5K9IqMhenFS2gqWXCR413mlomwVntBi2gn/wTYqiZldIjwBvxaiKfuV62EyH4y+NOfkwOEDeWijD3rvelzbeZxurVqNXpJt1Kh5lSYCQs7PvmRsWH4xqhclfoaCH0pfrtif3Xk1qhe8ZJ3S9PGsGv9LR6TgsqOkE6ifryXvyAHDheHlYfbxZcmrRcHLes9Jgmm+XD9kQRxAkWO/XLPXpCBTQNfXfUyPP5LlQ7L4Jh6seHVHPVEN+mVljs/Owq/HVCxgITCzljTkXCkUVID7ujzUSeP6Z+XQngd92imQsTlvgJiN/CoYS8NeYvenW9OCh+vJV/vJS12aNeapXNt8gIldOPc77TRENsgO+dOY8DdjWmekrJmTiOm4/CNk69dUUqfjsRfBpoNI23pi32ZK0P5cPBiGAqNfqaTPzdo2Gky3IVTedFSnip68XoRJTYDeLGALqljhbGRcW6ErGCloUvScSiZRGyBlUYHmPMTehaIHalgFOL84wVhZCusJbkJxdkEjdW0ogxM0UuIlUvodqH0UDMx+UKG2bl2rK0PJnvAkW5hsJs3ecot5kBV3hOYbYhL0uXYxXSvRimYE2FLAK3lOhsksQFsseHTF0QK16n2MhAkBgfLiRcw/3DgrwAs/+4yBW8UViR8U+B0KALeKm4wnfhq6Ljo1QaoVbHI0YhQvowQ4RQI7JYNDOjfUX2ZSXODMvqVOR6BSkM2IjAOAUHs2dDdJq9XisHjFXItJqTjWppYgwKGO0YFRnEMGBJXAQ0bEkzMHGBFVnMxmq16MzpquQMpdEKtCkZQGVKU+iNgNC0QqNFBCtU4n/8XwHXQrr0m6QQCP5jA9jw6ZA5RpUS0xblL7FoQNkuqlcUvkheIs+WzGRqkyBdiBbeBWhxPg1WYuN4s9kDpkTw+TAiwppu4oapNgZ4vjCC0QmE+mConbi3XCVNlEsIdIdF0qsyMIBBxoHe9JFGAfd+f7+PUB4b1l9Ohn9+OPDtra6TveZ7m/VX58s5QvbUqets8ZW5MRV5ErKzhFi7avTCbIauTMay3lqrv7fbCN1CveQsn95oQSkifaBkLt6/THWK4xP11sHH1B1hvwIYsihMImTtKh9qf3ncTtT05Kjt0Y3WRzfa7191XlyoWBsvWR0r3Z1tWBgom+jIX+grdlZo6a5OhR9d1zsrtZNt1sl2y0JPDmSMIr84VXl9pf5o0/H8aFDwQF3reHTIkL5/4u7ldvLNR3vNj2/0MK1oqjd1sFXLVEFmC65PFQA2NJW8slpNS2caO9P+gvpjXGYMwjtcq2VPm8m7Fx07M6Xzg1kDrebOxuQa5gmWamorDHVVZiFalSOrLdH1NWWSLJ/syGZqMmXBd3fbH13uJFrw6miI8ckQME22j3Yb6KIFl0PGL2/3MT8KNxaBejFOQP0S2XROKlc2yrYX8rewttFParJweagACOMxOjNH2tPpi8Ib9dizu6pz28otjpLk7prUkab0mY6c1SEbMV7u/N6lxsdXHcIEQ5fxipWmWsS36ZRJ02+SqW9ud9FrDNzaqDjeqaUI7Wiz8vlhG4Pk3t/rZ+Tf7y8m6c1CMzIu8jSSr1z/4dEQX+Lb2Yvz5twrU+fECmDOcBhh+C3ZWqGijpxjXF2Jgg2zF4XIeXf21mjR9YWKuxt4agqY1fP+tvPHu50/HHd8uN323a3W7+60i6zMYJzfHnX/8oAvtX+43fL8oObVVfvbw8ZvbzW/Oqx/faMRs9XxRun9XTvmQWqLGQ00UqfrKpV1FMs6S+TOIkl3eWJfVcJoY9L2WDrv9XiPItTaD3dbf3roFNSwEFCFTuhH0UwjRqE14xMHQWOyttAnENQteCmMlyASji6ntAlRTuScjl0/00XEjUcdeL4+QYh4A1pbA7jZLZEFMS28Zi+njbc3Wh9sV1+bLdoby1vuSplq1g3XKJn5QyB6tlnP+IpPCrj49fVywssoXRG/PLL/8qiemLOQ+nV1wxCqeEVehAhxdKNKX/SKvbXfHdU/vlT2cLfs5nLxxbHMBdxeDq0L+gWneaZFt9hpPJjOebhbwScDDRMY/+VJ888nDT8+qgN0yxITzAIHv+ToIEhhIPCoi+nZkx4WXVqsn3uh2aOAKQ7+8cRBTJ7jjgjkMjF5yp9IWqPs6bwhEvD1qdRLIyaM3OStx5uVY83a0RYDw9MEa1WTmWAPdYlDzSmOMll7tbqmQBjtV5YtqyqQ1xUphvjL35m1OVJ8ea6KEB0igX8so+2ZdUUySo+o9GVAkKt5Mh7maCplkZ4AoekGEhbFCeMiQ0UIYWQaGrtaVaikwfJ4f508zGqWUn1L5Q97oJWFphkSoFVWhv8YVTF6RaROHqGGyT6BmbjpycoURJ5SoiWSqYhOhuS0CUwpoAaXiQVuqhY3XMyxqAEbXhPrsss/paCvhVmfCAGL7IvZGMsxPIoUpoII9qXURzBDJcYCSWw4aceIEH8QExEUGQbRUhcUQ+VPaKAnzikQHuIlFgjBwbFR/tHR/pERvpL4EJUqFlWqkMeS6aT3BV5lvkunxhEtOqo++qrIAVNrI2rfTIspFT7Tyok/Q7riRTY8AZVsSqafhhYCzs5KhVzVKikcDPVGhDF20B8kSWPhYFiZFarmyenpKN10hd4qJwQN9Cm0gpRq9RIVklkn1wmxaJ3BqBP/c6lehC8KGPZF6UK0osxlgxOKPsyBIQFiIBpVCikCMekr5n0FI7TLe8VKwBnJC/sScEZgazQSDiWAXPWnjXCk4CTBzyWIeK2MgigR1E3hHYPaCW4nJMXzLmxoLv0vBIz8pcEQOvjd7U7Y98eHA78+Hv7x3sDnBIyZsLVCgRG6tdbwOQFDeLDd7Y2mx5fbnt5oEx1Dj640QsCvj7vhYECcGVKBgG9u1zIyCOB8FoEHmGolItKuDLFQ2wMOdyvuHNSTD37zYJQZf1szlYjg+wfD6+O1a2M1SOHB5vSWElVlZgwzUMssQkFUR6V+2GGlN8hSX+HmaMX+nP36MuWnrXf3nHcvd93Zb6NdlxuPDnuOLrbc2Gk+PnCSoOX67Yst2Jdo4yyYq2fL2PCQVlYPr3YxbPFwrQ4c77Y8udaDir250bA3U7Y+YiO/i6WIdKajSltTrKou0RCnKmeQtat5W2mOqrXaMuQgBVW1MV65NVlxY8Nxb7/z+a3h9w+m396bhIN5X/psX1uvZd4UZMwp4flR/4MrbYcbhAcacESjvzFV3dqpP9yp21+tANc27XS7JPZ+ca56a7IMQ/hkVxYcPOSwdlanC+xbbG6w6R0lutZSLSeVvjohXD/fn039NEcK/giwpt/cqQBMv+CExDBXyoifXWsHT6+2ATZkZK8tl11ZKD5crXh8uYWGaO+O+wBWqQd7jYjae7v12I955utb3Vzh+VxkjCvX3bi6WEKr5/nuVKb/Mj6PiAUdAZkHV1skrypIYoZMda6ESEZ/nWG6PZ02HfvTBVMOxaWJ7NfXne9vd74+bGNq3smluu/udP1wt5dDIX8tXx+2vLzWxLDCk0u1iF3mVKKbX11v5iE2/gd71UfrZfe2ax9earmz1bg/U7nanz/hSO+vTu6pNAzXpwzU6rvK5czvayuJG6xVzrQlU0h6Z4Nm1NVPr9YxBe+XE6fItWKjDBdxijxKH/KPYB4fo0F+f05jkF6cE0zue3u7neF9pHLc4MTwGZyoc4COh+zJQGMEI8bLe7kYugvFzz86ig6O1qouTRZuDuYyWJCjQ1+lYrzJONuSutaTfWncdmetgh/87U0HL8JNwmHgF5dwJHjr6i7p5DXBR/190u16ox7ktbjhnMH3clJ5ea2BmY/X5wtRlgR1B6uSBqvkBAxG6pVjTarl3pSLk9l0O7m3Uyl0MjmqfXOniqokWmcwwoh3BOKnhIsbocy0DPH1MZkDd76AkICr50kHtdci3NXY4tGEGwN/P+8nqvHjvbZvbzXSqOvN1VrKlO8s5TF2Arfz9kDaWIMSySskceu1ZC667AbyUNhBMFuwMv+ASUS5KRGuEXuRjPqhb3O5Nd5RqBiuRzdnLvXnoRMGm1L5LnuhkvbOZlUIs2ylUR4J0d4iXApVmNjjBmU8bhA6BmkGoWrWoIyCUJUJIQlRvtIYODhCIQlSJYa6WDZMEukN0TJ0jzUm1CsuzFsS6ZsQGRgf7hcX5itCh903Ljwu1D/czyMy0Cs6xJuv8hxZbIiSih1ZFHzM0Fw3jKo4ZhgANrxaYnRAUnywHJaNCmSeLpo1KtyX4p9Av7N+3t94e3xFFRCiFjblIuQaFR4IQgO9AZvE+Ej4GO0L42JUhk2D/C+gTbkIK7ttzOhjXEUM5Y2JDoZ6mdErsi+GJ76UEBeBkCWDSwzZjWwINSMlJzNVhDXVYDaoYWWeCRkDNrAvHAyzihwsClyVMoGpggz6ZY0IC4qODFXKExPio1UKKTMHjXo1K/9J5LoYuTFapotK0obHy8LjpWEx8UGR0TGJMomC9ho6osx6/nNFm1lhX7VaKYZ/xbAz2pcN1BsQ7O8bIExNwI0FKSJMSQCjfcn+ir2dVTopSV/R+Qz1UvhL+a9Qg/RJ/oombTgYCKFys86tgIV0tVZGUJwaZbFEirfA6hUY4hcUGoAURvj+CwHDu4C6I8wsdBqCj3+81/fhTt/nIWgnNkJbfF2xtLnyY6mrGIK+ulh/b6ft8UHnm6M+NBDxZ6LQTw4dsC8cTORTwEN80d0QsEC6GzVuUH20v1SMGoZmiFG7YCc6fUjXjq2qK+tVB6vVG9NFq2PF27M1h5sdi0Ol2zONG5MCB09150O6VAaXp8fk6QJpO9ddYwZ99tTh5szZbtvyYPHuTM2tLQYbdx9utd7ccrhxa6uNsDDsBYcRxSWTysOrq43s8TEBNvsLtVeWG7iO0ERE8m94Z7L8znb7teWGS7PVm2MlywP5vP7iUOFgW7qzzlxfZqAFHWErTs3Y+olQEdeqL8GfXHRxxrE1bj9YaLy6QkC+49Xt0e9P5l8fj788Gnl2cwgf2cn1Hpgevkev//Zqhcg5bcVg4vcPx9/cG2EDVXNW4Nxw93LHtY1GCJgOoNzk4mA+g4dn+lw6uC2rrcKI9oV97XlKgGetoVBFzVhbpZYY9XhHBlVemzPFmzOFmzMF2zMFKG8afSPln9/ofXql0413dwZIKFBie/9i0631GsiMh+wf7bce7zTQNvLSTNGVhVJmFQthj/1Wnsme61zcmy50Y2ssf3O0gBjg2kDBQH2ys9rAuFamytfYVNSBlGVKGKdalBpBw97eGsNka9rWmG2pO21/qvjOOrTa8Xiv5Xij7sZyJfHko7Ua/IDoWijq5krF9cUSxjBcni28Ol98Y7n8FtnuzVpGuAPOAdwJDTtJRuzNVE22ZVIv5yhW12RxSjNyKOG4Vp0RY8+WMLu+o1w90mCGp68vV/MjELtmSi7lAMzdYgCXiE+c2isGiogVfcfh8kbH9/cH3h51PTlAfDsf7dW/uAaxdYA3t/in1PnuJnB+e6sDcJhA0wMm2rJ+uNsB4xJOJ6j+4/2uH5mXdb/vw93BJ/vOWyt1u2PFa335ky3pnBU6yxT9NTpYZLotg8/w6lwlgfonBy0cl9/daSPqDiB1qJ3XIRHOy7671SICnuawwtGEVTyjEEh4f7uNTDlxAg4uJMsvz+QfTBVuDWZPtyaPNRhoK9ZO8XG5lKzqcIOWJif8iXAOO75Y+vBy6dPDqtdHdP6if6erweeDdnFwL/bymytC3OLdrbYPxxyVurGSAM4lODr59LB2ihA/SdHm+fPDPsDgYfD7o8FfGep8t/vdjda3V5vByXbNnUUmPlXenC/bHsoddyQ7heYtanwVjip9HSfdXHlBWlymITxDF2aQ+qQoghQxF+RxXkqJj04WaFIGpcj96XvVWqQcakhZ7M0nFDTQkMY/kKocOV2XTeowTWJweMDpiMAzEQHnALQHEKMA+gSwHWCAvBs85DmMs5XHBcOREGFk0PmoYA+IFhbjS3xXVJCXPC5ULY2CTSMCPKODYd9gGUHHAB83FHFR0uhwSXhwTEhAsPeFUF9PgYaDfVnjwwMU8WHIYkjajWR1gsWgAGxg68hAjxD/c4E+ZximGxOGnA0AxJYjQn2hW9jU3/tMeIgPYBMXFRoREgjiosLFVZ4YT6wYuk2SRCGLeQLKWJYQR5Eq9Iw4jo8Og6RlCTGxMWHRUcFEhpGhOo0MmmQIINoUDR0ZFgBnI3Mz043/BA9dyEhLBhCwCMLRlhQ9YKNnBpFCqlRIeDVeCu3LBq6FeuVJEoWM9laRsC/9Jpn1q1bJdBpFskEPVFqNKjldlpwpM1iS9Glxcm28TB0rlUdKEoHAwVT5KlX4oPBeiYB9CUQjfJl9BPWK5UDihhVDMmlgIs8woms2g5aML3lfsTJYJGBWjT6J1C9FULAvqxhzFkPQrGKNMglgIUiebiKiDg3TKos0MDXHksQolUpGWTDFToSdeS9omBLhiOhQmNg/yOdjCPpPTEAPh7+73fP2RgerG4/2Gq8vlNGqlwxrX72moSihpkDSUK5y1hrRW2QZ10ZLD1ebHu93v7059OsJjhtCkULNzJu7XahhqBf5SxUKTigMzwBX1PdPpuEVyofgFWgGeQcNsBLpJeq7v1SK8rt1sY7+jgzHJcN6bbP+xnbb8X7vgytDiOAbW923dwdWR6th4vn+UlLCzL4uTRcOvBWZEtqs89CeJ28q1rZV6Cc787ama69vtB/tdp5cG3p2Y+zh5QF6NV9Zbrq8gLu7ZmO8nB+Ble7N+wt1dHIWr/AQAX0wX7c9UbE6VDzblU2588pgIcL64lT11nj5+nDJcn/R+ljFdI+tp8HSXGGoL0tmXmauVYXlgRYzhJ7S9HHFVlVfYz4cvDPpWBmq5PWheegfGn54pe/ZzZE3x1Pv7k9993AGoIk/PJ779eXq9yezVC5BuqzPbg48uNx5fLH96GLbyc3Bl8fjz45GOTfQaxqwITi/OV25MV2zNFrW12ztrEtrqzI1lxlr8pUUbtHxJ99E35+YsszEhmJNW7V+vDuHKq/VydKNqZL9ZTtVUohyqsjubLZcW7QDNhyn3HhxpefBTuvNZfuV2QqwP1W6O1ZIaPfieBF8cGetga/e3WxmvbflYBQ8FMJF9lx5sNN+ebp6a7RsqjWz325urzQ1luir8tWVeZrybFVxhpQCswabpqPC1Flh7KnWj7WkzTqtS725y32MW7DtjBdfma8+XK4/Wm9ivbpQIzDlUt3eFFOVCllhCAh+f7Z8d6JoZ6rYjd3ZioPFmp3pSsrkxp05Ex22gcZsR4mhqVg4mpSmS2ymKJsxusQcV50hq8/TjDZljzRmDDem4tyZdVp4NWrf6e+xM5HnxmSbbqEnBUG/P1c825lM8weeQ/ny8UbDrdVa0jQH0yWsHB2oTL231fTisvP5Qfuz/bbHu80PtuoeX2x8csnBenO59N5WDcoeeoZHj7cqBNq+1Uu3UX5eIgHjzaljjWl9taa2Yk1jnqzZpnAUqpylOq4Q3SG9wp/R0UYdp6J723W31spvLJdyIuEUcnm2+NJkAQMqrs6Xci65OJFLt06+xNGElcMKpwSC80jbm6slLkCcFbvjBUtdGePNZuIQzTYpp5Oa7Dg6OFZmxDUWyDurCJ9YFvrS1scslxbyDjdKb29VkJt4dND09IqDkwcvyI/zbL/l3qYdPNyuf7TbwErwjOP8lf4nAABAAElEQVQ7dbqHS2X8GuGEhKp+zMiNg5b3d/qeXm59ftD68mr76+udPO3X+yPfH/W9uep8tue4v1p9Z6Fyqyf92nTp49226/M1q/228fZMGmgIrTPylBV5mjwaViRLLNposzJCHe9nkIaqEwKjQs7GRnrFR/sSGdYkBmboIvLNUZUZEvpCNxUkdZTrneUYR9SlmfIMQ7wizj8Ogeh9JsT3bKjvBZRoWIBneJAXc2OjQ/3iSI5G8oK+AIYTH7JqFfF8FbCR0n0pKpgn8I18KdTfg+9VJ8Wa6bGQGKuRSeSSmLAAX3/P84BNgKen7/nzjKVlWABrmL9/dEgIe1lcHASkkSXqIJ+oiIigAJ/zp+IieGV/N3ioQwuqkhKiwwK9L/heOA38vc8F+npAhDAoqdPQED/it0zoY4U1Q4J9ABvUZHCgv7+vD2tEWEhURFh8LI2rYrjuRmR4MM2VFTIaXESEBPE6JGLDRSKEC93gBoW9QhIbGQxQtylGoZSIgqIMiyE7w5Sfne6GLTcDNQwBi9rXtdEjf0kSQ8BIW15NmhgniYsSJ+mGUC4bGkztEBVE0gSJXqsGKgVFxhpoFCjVBHktSeYsZWqW0pSRoDJCwEz0jYqjQldPzRCdqIymFFcGWAEBo4ClUvpywL5J0XGYnqNQvYBJwNTmUhQkxp8xKlMvJE2Kp1MHjT4Qr2JrSbiW1K8QczbIWNlTB0UmGKeVG6R+KZoCbMTsLzpYBHwsghwwBMy7UP7ETyoK4mjuISSA2YWMKz51+h9fvMJbdKXlZK/h0W4dexEExPjXstqfPlivoIc+BIyDBu8MBMw8hkE6HvcWkNpEAT+46Hx1vf/HB2NkB/Hm0AqRtCLyl2JWuiBRz0rZK/YiQI8noqwCo+yhRxsYsnSNX1ibDURi4Rg2NzbJhraLNcHXt+qurtdBEvv88l1zXFtve3RtDDy8Mn5lxbk6UTs7UDrYmtNYoqWyvjxLCseAymxZdZ6itkBFKw9nLZWmeSjmS4uOwzXn8S7tIHouL7YczDXtTdVvj9esDlcsDmDgKl0fJUtUx5e2J+1bEzUHC44Xh1P3Lw5eX27jmQvdhWC5v2STp03Yt8aq14cqeIjOHmzOoESqIl/FXEy0L1Xt2CI4HScrYi2ahCKLtrEojZjwcFP+pNMGYaO2RW19d6/z8dV+OPjl0djrO5PIYtQwshh1e7jeLEpzNm5c33RcXW86uuh8fDhEaB0uBzc32x9dGxJMapMCB29M22kDMtZh62vKbqlIsdu0pVZZfkpCQWpiUboczqst1HbWW6b6S5YmqlbGK4gr7C9zIHDeu9R7cmXw1mrL5Vn7lbnaa4v1blyZqbk4XrY+UIAs2xy0rfXnLndnzTlx8ZRcnqk8XLDfWmm4s9Z0dbYWrmU9XKhnPZiqujRBRVDten/hYnfBUH1aS4muLl9VnqmwpdHIXsbv0JzkeBqO0hm/JldBl3xoprcmeaAudbjRMubIGG/NmGrPWugpgHU2RjjxlK0Ola4MFHP6Weor4DzEutCTtzxg4zC0OlKyPFS4OGADdBQnLz7Xnz/dk88xcbgtb9RZ2FOf3VBk4FDC3xB+L2fqwuiwlpYUnC6PsCoiC03SErOkLDWhwhqPHO+uNWDhIWM90KQXMdTIr29pT42SDUWlc53ptLAG813WzcF8PpCZ1lRixYhIPplJhwlKW8SCy7iwvuztofy9sYLbK7XX58oXO1IWO0xrvZadkaz9ybzJVvVyTxplfhwjxppM7aXKhrzEpnx5U74SvV5kis7RhaYrA6yqQDY0UKzNTmovg4mNeA85KEy1mccdBsZRoFa5GcGUVKMZIZ7fYgYj9er5jjThqDRh2xompm1mWAUkjYaGmz8hf2fUttCdLQjuejNxAs6vecaIdAVdYMMKTQmVGZq6fI29QNJK7ryeUaEmPpBRh2Aw5kOg1mumjQGIls2BnP2J4q3B3IX21MlG/Xpv1kp3xt5oIZ/AWn82TxvlDu2qg+myk0sd390Z49fFs0ud8OuDTcfd9aZ31wae7jpvL9qvTpbt9ueuOi2zDckbPXlz7ZnjTZa+OnNndQpHSRovM5OAHk9kVTUJofKYIGmkvyYhXJsUiWokGEvKk+ZNalkkGVnoOccUS1f5ulwlf7vaS/StJca6PF22UZKqiua7FLGhMSF+caGBACUaFRwI+QHXxi8swDvY1yPA6xxriJ+nCBjRz+MMYBMTFhgdEiR+S3igX4ivN+B75ZI4aUyUGeNPQgIs6+/hAcL8AwM8fbzOnPc9L+x9zl6gDMXfwyfA0y/EJ5ArUUGhMaHhSolUJZSxRCXRmcLX1w2oWhoTk8iv7YAAXDu+5896Xzjr733Bz/N8cIBXcJA3txUc6AuPipwqDsplVi5XIsNDA/19fb09xZVKVTZBAX4QvRuwMk+LiYqMjY5CjELDcDBMDA1/Dl5cfIhuRj0jZyHgNLNOZN+8rJSCHCu8K6LElg0ZixwMVQNR+6K/UducAETVyxvRtoLCWR8fz4BAv7CwEDiY0wANn416rcs1JXSPTJRIEqDsZGtCsjUx2ZKoTYGAk5R6hUqXJFNpDCbm+kLAhmQzcWfYV9S+EDCds6hKolAY+UvkWQw+w8EoYAiYwlwYEcCRSFVpUiyJW6Y40MzSRcMq0X71OQEzi0kEpAtEMuYKwpdwOuxLuvozkIVWwO68BTQvNgbhjzEo2E8kYKYXnz7z1Rdvb/W8u93LSt3R6xtdrw476QtItu/t7d6LUwXYDme60vjnxxRCZ60eAsbvQM9FopqYsAjGIkrub7e8Ouz+nwiYBLBY7Pv4mtNFvU1U5pBn3V+svLpaT2QYRQghwSsIMsqKEL77K1V7S5WuBHD5xlTZ2njZ8kgZcvbqavvOfOPaZM3KeM3SSNXMQPlwR4HTbnFUmuqKDS51RXhTiRcDR0ZtoZKKKThyrqd4oa+UOPDOVAMZ2e3J+vXRmuWBcq7PdNpYkad8dWWgfLbTBtgczDmuLbbfWO08Wu/ZGK5e6uW3f/nmSA1P2xirXR+qWu4r47tQVx21lroSU346LXKUePpx9qfqklI10iyDstRqLE3X2HOMcPBUZ8nWRNXuTBVDkxCvd/e6jy923d6hQ0Xf/f0efvyjnfZ7l7rRbdAJk6aoLxprS5/pzuYhEy8OVpouztsvLdWj5vmua6ut4PZON+eSO3u917eEVlxLoxUcSsa6iIoXdDVkt1Sm2wtNxZnqwnR1Pk7LVHmhlV5m2oaq5K7WrKHOvOm+wqXhUk4eHDj2pu2LvTYCtlPtGct9BW4Q/xyqSyYcyjrWYB5rSB6s0fZVqlZ6cld780RAz/POrNm2DNbt4dLNgeLV3oLlLpxEeeMNaWON6eiP6kxpMeWPxrg0TZSV4Sra6FRlRIosOEsdXpKWUJMla7KpWou0oLlQ01qqH2rKAGQTRIw6ssZacyba8+Z6Cse4+aZ0VoKK+OGpv6I3y3BrhgvpdDOlSg27zVhnLjXr7dVm/oAai40lVklNQVJZVkyeKTRDG5yc6KOL81FFeinCvdWR/sbYQIssjJupzJRCQngMW8qFhtUiiH+2lytYO6s1PdXa4UZzcyH3HNliS2grSgJOF/oqNXxEgzX6yea06Za0iSYzdDhQrZltS4MLV/uytkcKyLMS76VECkYEDKIYazJ2V6uIlMJ/UKw9R4E6z9KEckTQxnrKw88oIs6yMScFWJWhgmrPlKKMGTJvz4mpz41tzI933Ya8o0TZWarpqzCM1qWM1pm4md4K5XijyX04wAreXy3/+NYdyXPAaebde6pU7SUyuJ8wUl5yNG+kjvI2xgebEiLNiVFWZRx/TNnasOK0uOocebmVIBNhAxXSvLsMh3baRq9tZ6j0+kwd62yLdbhav9SROVZnXMSh2WLhb8iQXfDB8deGvzz8VeFId7zeejBRudlfMONIG67RTtQnTzenzLemL7VnTDeaB8tVE3bTrCOTtD0/aSGGKWUw57ZMmj/o4nWqWCneogh/YrbEeBXxESppDHqURoZkNKl1oSkExTbEn3JTpBz4OEC0l5r7ajNBa6mlxKLOTpaZaQ0hj5fHhCliIuWx0SAiCDYNCg8KEtyp/hRqevl4UKV5hhWeEwHtedC66Ow3XAzw8Qz29+PJQijRj6ZGApjazkWQFE90MyYUSvH0AmxC/YO9z3t5nvUI8PZn9TjteeHUhbNfM8f9vMfpC3zJz8PH39MvPioG8Os6LJA7+QgecpFeDki4AG9f7wt0UjrPe3F73Iaf7wWPC6d8vM6HcZJwZVJDUVe+XPdkExocBPt6eZxn9fa8wObCubPnz5728fJwA3HMHpUMBzNliCYW4hXWzwBtI6N9QUx4SGJcdJIkRiVLxGYFuULDaFziz1k0ObYKsOVn5uVac5mMKzxMtaQmm5J1pHJRtwD2Rf5q1HI2EDBC0MPjvA9trfz9Q0JCJBKJTCYjlKxQKBCwMdFxkZHRDDcQCThGYyIHHJdEl0itUq0HWiPdnGm2LOR+RQVM5BntSyMOCFiuVNCsA9VLxhfAxPzZkAn+OKD3Uw9LaBKdCg27mlZSR8RQB6GnNPHkzwmYel83IODcnDTwuQIWfFi4rjhwuIATGy8YtwGoSnLRfDxSGALmB/f0Onfm7NdfCNx5q++746EPd4dZ398eIAsI7mzVE2fDwT/bm0HzXpKdPQ5LA2k8V5FrX2PKZEfm5QX7/d32l9f6frg/+tOJ0JmIMlnkL6U7dFLE3UN7LNpdYe4FT2504XjC94TFCRsRcULYCN69zfl3p5MgMPTDxeWx/KXR3IWh7MXhvKWR/AVKgXtzSWHODxCjbl4eq1ydqIaDd+abdxYdG7PN0PBoZ1FXU1ZLjaWyQF2SLWNmJ16M4qwkmBjd01Zu6qpNHW3Ln+4uwke9NFSJoVrc07UKDhYJGH5d7CkBbCBdWHZ1sJJ1a7QWsPlPBDzpzO+tt9IhpCRbwcQSzuaM3HIRsDxVI4OAi9MNeQZmoqW2lVlXR+quLDtQtPyw0K1IwKxExR9c7nUTMKKWCDmMC+9yvkHYoXSPtjtubDuhXiIBF+frb6y339vrB2xODseJsa9PVM4OFFL1NNGdPzdcvjBeywfS15zXXJVRU5hSmK7NS1FmJCelGxjSEpNhismyxNJjr6OWZqIMwLDN96Lmi8ZbstCdc935087MWRdIPU61WpFHIqDVpc7cuXYr7LLDsWC4WNDEfUjAnLU+20pPPtcXOjNdD/OhYRTMUJ0ZRUuQmSFXDIDLMsSmqiNTNDEmVZRRFmJIDKDpd2Um7EsgOmWsOWeoPgP/Nhhvy4V0YV9omEBoT23KYKOVh7R/GWwUVBGrmNxl8FxzkYr0f1ctSAbddUYizzO9xfxZY4IbaS2gOotYNy1cqFERaDhTAtPQ5VQV6SENPpsUckET7ZeSFJ6hjSE8XpqZRJPClmpTW62JbAvA9cNxU7TdYtsmWN3PUM5KbRte7lxJZ6lqrD513pnDEYSPaKEjW/zZOY6wX+rKhoQuTRC6L17otIL5jnSEMqyM93tzpJBqGUQ80ZTOSjP0X0pXQl2kRRaii/VTRHgoo71VMT76hECLIizfGF+VpWoq0LeXGQgVjDSlcWCa7cwdtCePNFimWrPnnJx40ufacufasscbU4D4Z8E9cBpAo6PO0aO4z9xAeZNmhrxJl2ZpAi3KIAjYKAk0xoeqIwOlgT7SIC9pkAeUbE4KytQyoyyuwJxQapFXWpPqsxIn69N3BisvjVbtj9Vs9ZcutmdNNaZONqQ4bdKhKt2oPXmiKXWgWscBpSVfwp7PhNPJ1dm6BxsdV6dqef5wtXGq0TLZkDZRlwrGqpM78qQTdRZ+kP4qM3HjxkJDTZ62ksqcdDXWYpGA0buu8K83SjQpLjoxWjAWYbLFmkv1KvZgSn2yzEmlGerafJzStpmOCjDUVNRRnWsvTMkxJ6Uq4zVxURpJrEYSr5LgZwoKD4CAQ6A9qBTG9Tx3Gq6F5OBdEWe+/vLcqa8AG6/z50S6jQghjXte5F3Ps2fBuVPfiA8/J+DIkAgoVuRaiNbngjf7s1+fOfPV6XPf8F0e3uf5MtHsaIg2PjoKznFDmSQlZswbQfYB3t4fCdj7ArfHffp4n6X94bkzX/v7MQshhNAxHAkfAxdf+sO7kC6rKII9zp+DgHnoBlcAD+FgCBt9jFAW6Rna/oQLvCDkD4L8vOFgjimxkYLFmmSw0GfDZbCiEQeeKQDpguxMS1ZGGgldqBe6JYINMzJMUIxmc3uQOj8S7ye8oes/Pz+/yMjIWCjS9R//j4ggNB9FqJkQtESXEpWkDomRRsVKaUwlS1KplDo42BWFZqMl4CzFUp2IZpbExERBwxAw2WaKjkj6inlfUsI8hIMRwXSLlCsSoUZEKivcCdhAwCKwU7mY+GMImnIjN1y86xbEHxUwBAyFU4AkAt7lHMDtoMu5wpd48cio0MAgX+DlfZ4j2BfPr/e48f4u43dwT0y8vj14fdVOjSYGQjo8DDRZOutSGsp02B/Kc1HAuqEWy3xfPiFosoZksJhc++RKO7wrTOY57mc8MEW39MeAdDHx4vLF67tHRnmmdGemXMB0JXKQbCvdPHAzsQEQD0FafEZ7i9VMIGbG31x/7uJwAQp4Y7KCZOfaeMXcUBGtOXYXG65tdu6tti6N12wvNK9M1E0Nlg91FLbWptUUa6jwS9WHp2pjMwwJ+WnyokwZUWKMypTq9rUwQyl3otu2MVV/uNXLujFh3xivJgpNRBqsDJQScCYQjdia7y3iOgLx4kzD7nQ9F9dGKgEXWXFiM5aR3u6wPmNShE43JuEff5r+IwEXWfRVWabSdFWvPX/CWQRN7i3WElHfnC4/WLTj8AJscEcTlyYMAPbm7JeXGvlA4F0+EGh4daTs4mwdTcdY9+cbLi82E8oW4LoH4YaHhCJpAaMVK+NVVza716Ybl6fqR7qL2+zWqgJDfrqqwKoF+ekaXVKoXhamVzLxNJ7odFmGvK5QzwFlqgsaLlocKGLEJH5RISHqAunbyZaMCUfafGf21fn6tYHCxZ4cErSEXolC399uIxANtWwNFaGJYZcbi3XrA3lEZfnqxnDRYnfeaLMVdiT5WpJO6i4uWRmml4coJX5k75JlQUShUcbECQXVW58GsY02U1FWQPyZ4DNgQ2y2KDkQQDkcEbgxNthq4J7J1mwhXt2SNe3MRRPjhBfN8PRJRTFD2HPdpXPd5SKmOgqHW7K67Wn8vJhxsvThxiR//Ds6ia8y2lMeeV6T4GtShlgNkfyFKWW+ep6cnir8tedkMztYwEGQ4yDtX/jT4fPnJuE/Thi4rBe6MJrR/cNG4alYewrFQn4cRyYdKZDfPGep7hyRCHnISWWm1cLnQ9J31JHKz8I5A1rlo0DmEhK3KqLVUb6SgLNRPl9Lgs6pYvySE4KyNREksO05Mvy9zjIVQhznGgzKaYmj0rQjY6YlE+qF5Jac2chQsDdafHmq4tJYCSeA/cnyndEi/mjwNLkxQkuyKm1Xubq70sBBp7FIg8bNo2W/PEQV4cM9xPp+Iw/zFDSxxB8prI/3hYnpzc7A0OYCTW+ZaaIxc749jyMIRDvblo7mFjHtSOe4xrGM++EoxllE3Cx15q9023ZHKzcHStnPtuZs9JRMNVi7ClXNWQndReq+UuNojXWoxjLuKBhqzKO6vas6s6/R1lSWVkinJ+bwyMKlMUSAvUN8zkf4+0YHBSdERJJAjY8MJS8rk4QRhRasyPLIAovGWZPfa7cN1ttGmwvHW0rG24t77Fbhx0yXmZOilVERishwWVSkXiaDgD3OnPM8ex5yDQ3wxZoU4HMhPFgQxAhNONhNxnAzHEfjYaH3sEsBw7hsWM9+8zUECYXTjR8C9jp34dyp06y8MhSLGr5wGlWN8rnAhi8BNhdO05TwVGRoCEQriYmMDIWYENM+2KaiwoLRmlAdtCdK8Atnvj57+quzZ74M9Cew/BGwrwiEr7fnOY8LZz7CRa4IXwDLwsQiRNIVr4tX2MO7IUEBqF6Rg8WviuuZU/849c2XrIDbgPgJEnCHOLYAdi0C10H+AVT0qOQqjFZMrs+yZuXl5DK+wGpJh4TVKNHYaEQ24e6g4ADy0l7eHkSeYV/2p0+fPnfunIeHBywcyocawBMENexP9D4giGbKwaHhkbGS6ASpmPcNxzEdG097Cy2VSIlyqUJNA0k2cdDdPyEEIj4iPkbkY/phmc3J0CEqWdSmSUmJ8ZJYOBJqdIM2GlAy4WLaWuGoIiKNGiZJzNBDN+jFAbjIeGDCzvjUcI3ptTi/ZC4Itci8LFntj0cBioE5rUhIKQSERwSjgPlr8R9f/u8vdidtl+fKcHYw9u7xgZO+gJSNYmnB/Tvemo7ZmAlFZFWrc1VYGHLNcTmmaAwROFp76olC84uS5n8FuxMltDSi5JTYMhHmvYUK2iIyJ4CZuBT2rI0VLKJoh7Ip4xNGJw3bMCGL1AvfYIzCDMXvNQiYvPKlJfv2XMXqeOHCUO7nBAwHr0+UL4/BNGVbszynbm3aPkfMc75B4ODJWji4ry0HDq4qVFFfLwg+nQQapuVbXlYimq+2TNuEEanHtjHbeGW98/pmz9ZM4+5s095C0/58k0ixVDGBo+2uZzcmHl8ZhvMO19pYtyeFX7ufg5gnnwDxAN4OWcnML3rTCF3OBQIWQtCFabraPLO9wOSstPY1ZNEdmppmIur8KuecQaIXsMHMTD+Kdb40UUq10kJ/AdS7MlwM+7IHcPDBQiP3IDIxRU0fb8PFwRwFVkcFbE7Zr6w7T27OPDicunt1bG+lY26ourcl31mf11CWXparL0hXmBRhBkUoNMwvMos6KkcfW5Qm5M5xSNHKg/ouSorx3bjBL3o4BvbdHa/YGCqBUEkZ4pNa7csBW0M2SBfGBVAyD4myLnRaiLhyhRIguIHkIvZjjHJZxkjsqfhUFQl+VIAkRZ3XxvugtwhvlqXFMy+9Mj3CUSTtrtKAjgolwV7AJl/v3WSTEBvfmawcajBxsbdGRx4U31B3lQ4nM2IU5iaF3Fmh7yjXimt7qRofU3uJ1llqENFTlQLN1+XJkeMCzZgirZogiyYkWeanjfeSR56VhJ5ODD+LmRYnbZo2jHHrmGyLLDH8VW/jTuo0fc1C9y5CFPwRwL4Yx/hw8ExNt2XxEUG9084UsNhDi0QIOIsPB9FJALa/Sg26qYAqU/ZXaQlNw1KtRQlC9LgEE3gyP35pahzzN82JQjDcEBOA7ozxPhXrdyYxxFMdE2hKDM3V442SEJXlW/rs+iln+kJ3BslgSBQaRu8SAO8tV4O+ciWYaDAMVatG7KrZVjO3gQKmrqk5N6ouO0yEPTO8NiNCgDWKDz9T5Zmh9MpQ+DF8jGi8IdbHGOebGHQm0us/or2/jPP/R3zAV5LAr0F8wJcJ/l+WmuIqU+KrLfF11vjOYmVjVkxLflx1WnB9VoTrR9ZSft1akID8bbdJ2SCCm3PjGrPi6jNjWGstkWXGkEKNf4k2oMIQAkq1IZXG8BJNcJU5pi5D1kigu1DXWmJqr0jrrs1oLDaVMAjBEKuXBslifGOCPEK9zwR7ngv28qQLL0zse+6U3/lvgrxO4a4K9T7FEzTxYdmGpGx1XFkKJoOUnpoMEhy0qUHuk+83S8MUEUFxfl7Rft5q/EAh4X4XPGFHH48LYUF++JvIsMJ/bg4m7QrrADYx4WEyIqUSCWoV3kWesiHsDCXzJeBSsdFi0JgVXheo/RyJWzj4FDx96ssvv/r3fxOpF04FvLLLseyPuwqB7ON5xs/rLIcAHmK54ornuW9O/eN/g6+/EnDu7D/cOH/2GxFIYZEm2biunEbvijh35tTZ09+cOcUT/gUiGYsKWIxUQ8nu7xI3sO83X/8HKzj7zT+4WzE+z41xh4TBIX5fL7/oiDjBp5WkMupMJqMZ6NQ61Cj9oGBfFDbUzluc50XPfPPVV19+881X586dRqF/TsCenjzh/IULF3x9fWFfONjXx9+LnICX97kLfIoewNPbJyAomFHAEVHRAaHCoIOIqLggCmxDIvwDQrx8As57ePn4w+0+IgKD/Ekww4XMaYCgYUSSzVzhKID/i6+6IKhSEZ8y0xfYRNAeJDYsLj4iFtdcpL8b0THBgEmIVBzFx1JAFUDMX8jER9OMWuhHDXhxMvAcMng7wNsxpwFSJx/s6+uJA+vf/v3/+4Ips4t9mUyLo7yVZlLEnDdGC2gcM9OV31Obxr+BcquU39Q5+vhMXbxFHZOuic41Scoyk3AVEiPqt6e6ImBC+pDid9pjUfNOn336w+FkgV1oN0gfj45qOb2QAK9MbY9INnAwlMOK/RimQVLDPQhEV963hLIZuMqlgAXeAohgrEO7c5QqOfdXHOjgvaVGmHh7roHcMBw8O1SGwG21p9TQOi5TiXEj3RiZZqC7ejRd15nxWVEgJY1NLH20K1eM2c73F8Ne6y4RjJpcGSrFy8OdkH8lCDzVmYUYJTwOuFWysIArMCKESlSzvTrZ2WChoR09XQ3qKPq9UVCfpkvMTlbYUtVNxZaOmsyOWuuAg/NHMT/a9mzV8mjRldVG6qMAG4IBfFBMUyAgvzZajBrm8+Gim6T5fACfDPcgvLUbC43c7ee4vtF5h+j0lRGYmDT5VE/RQGvO/HDtULutucJcnqPINcfQggAiTGeKS5J/MhNdlAEWZUCuIbTEEs2k56YSZWOxTERzkQyGo0aIX/edleruCjXJ4OEG46Bdx29zkWMOpiowYeHGQmOJBEwZKzTMQxTeQlcuahUFTIsiQrtQmjDHTUURSKCWMaWKkCxdpKiAW0o0JeZgR4GEiOignZpdE+8lvF29iRe5vth0f6cLCX681YFTbGesHOxNChZrjgWbw6U4yA6XWq7ON+5P112cqNnhODJcvtZfOt+RP0+M3YXlntIZRmU0ZvC3GlMYRSktZXq7TY2DD48PNS2pypBUdSgfjlEeAAEXWZMclSmkkFvLDfReJRDNEKep7mzORgIGinHCTzuz0a/znbncJPFkcroAU5Xo38axvDfFrZbuEsIhHtCTQ0jf9cziS9NVgtN7snJ/tp74ClmAgfqsKobtaKMtigjoVhsTKI/wNcsi09XxBSnKMqu2uzZror2AFAmWNJL0FyfK6TJxabpid7SURAD6EpVJFtYFC/nXjT5cUZaZlmTMUMS9xaAF4Yq5jgw3OMrwzxafP0dt/pQ5zVCdRSraUWSssMgq05XcjzbaSxPlqYg4Lws7a5IGWtURtpTEygyC4caeSpIUhWt9ldNtOUQC+LPAtAzmOrKWevL5AzqYqjlaabm13HowaZ9osiDTCdQjiGdbs3g4WGPsLdc6chPabTJ7elSuzCtL6tnIcbBAVagNzZD55KgC8nTBNmO4Ve6HH40DSoYmNJMZRPJQVZx/YpiPJNiPOtYoinz8vKURoQnhgfGhvpJgn8RQP308H11Crj4JH4ajyDLaWrY0WLc707o/R0lCOb+4KqzqfKMyVS5RMzOH4XYBAYhgV+Y1gJoc7LtUzhBEtaanpKUYiaOmmvHdUGdiFh4mG7MzrTlZGRaMNxoVZl1KZVizMtJF5OVkp5qTkX24i1nxNyEuxbguoWC0JoQH88FJAlz6FQ7D+oR7GT4jsOztdcbL4zQQ93T5h27//d/+lxtccQN2dAPe9fI4y6sR4/2cR90EfOrrr8A3X/1DhPgQbuZ+0LusELD4ZC6K+FwBf07AnBIAt4rsDvTzRwErEH5KErg6KnKpwyUgzH9oWBLijEkgJgwtwUkQMAqY1C8EfOrU1zxkw0Munr1w/sy5c+c9PXwJuQcFooGFD8gHxg3k4umzZxD4gOsMYPD1D+R7vP1xnAeKDA31Qs8CfDw8vM+JgFbhPID0hB3JwnKFQAQBcK4AeBGudQN29CAx4HmWDYGMkFC/sHC4k8MA7/sRRExAaJhvTGwIX+WU5esHYXshcN3gJ+W0wQmDH5+XIubMOxKCxndG5vvLf/wfgYBhXzdo20bREYFiQm3kBQkBNRYm25IlpsTgVFlUmjI+RRabqojJ1MWSCiKM02wzdFek9leljjVkUGpCeHC0JZ2yAdLD5MwgY5K71N7ALkLTwckyphi5wAZUIPKwGpFXo6MNDwnACvw9JOR9hdGEwwXUuYoEvC5UzpTRlAP+w/d7bb0FQUwRzvaM/WDZsTtXB+DgzZm6ucESxgK28ku/WEcyrzg7kWknGfqQdF2gRRuQaQykGWxBekhpNspGVV+Y1FqOoSx1pC0LOw++Hm5evCUcN4Lpxq6HjLlP1DmnBIYMLo0Uk5oFk105tOQcbsuZGa7saslj7Am9zmmRQ6YK5Z2dLLWlydsq0wcc+Z32dGYsIt/dIejduWqRgNlQcAzIBFOhBPtCvcSlEcecY+BgwIaPhXe/turAsSy+u7jSZIMYpgjKeFznmEIUM+Hu8Y6smd7Cub4isuYz/UUj7bld9aktlfqGYhVJUFiHgY9Z+tBMXQimpEJzdHVOEjp43Jm3PFKB5Q3wOsjuS/hrJjGplV+aqrmz4Xy41317g8KkekCcmVqjR7tOVsLR97Zar89XHa3WU4bEQzgGaiRQTOC3qZQ/C1W+JVGYk2ohGx1rNUQXpEqwR9E7c9RBPNkGjfFbe3+mFq69ueJgA9hArg92u6HeK3N11xYaWQ+Xm7lyj7z4muPmStOtVR523tvuvL3ezpO5T5GDN4bK4OP96QYRFzHQDVbMddkmW3On2nBQc9iqnOwsxGRLgIdiLYLSHFDStaFmuT+nE7M8GKapzlbXF2j5cOj50NeYJnyqXbnzfbivy4iUbI9XbY1Vbo1UcBRY7suhMgrAwWuDeZQVQcnIYmIGEB6lPr3VwgmGeD6xAehzZbCAD3ZttNyV2LY6y02kw0n0mqUhyQkh2rgghK/r31pCYZqmMtPQYDMKDc4aBX84RE7YiSwyZdafkvE2OHiTRjSgvwDsDBfuj5diw8acLLIvpyI2VHkRw/iInv9L1304yXVmV4Lnv7U7EauRRhLbselJ2IIv773P8t5774EqVBVMwbHgvfceoAEJetet7pZ6pJnZ3dnfy49dTWlnIm68+PLlSwtUnu/ce+65jQ/OjD2/PKvp7vGFyScXpz66Ov/J9aVrh0dP7ek5Od+/f7RpqKGgrza3vSLdt9FYnOjYWpbaVp420lQ81VY+31e9PFh9eKLBn78CwXK//VmBzxgS41f2tT8+Pfb41ISEs7TzwxOjL6/N//Dw0MMTw7ePDFzZ13l+oeXiUpu1BVXXufnWu8dGHp2ZvrbSp6yguEBwtzRcQROwPFwVbZgaMs0Lb6lM8RNUmp6glFuYsjN719a0rRuL0pPyUnZkbd+YmvB+5pb1FZnJDQUZNTkpzSWZfXUFMz3VS+P+iEZvnZpRS1oeqZzqLOurK/LdVuWkSkRvePMNMmNJ4JyMFM5N5EVRXTleudSTSjSkUVWOUahlwlQYLHTLwF11TQxPAXXThvWwlo7XHTlZmTRNbjpmZaSlJmt4xX0M2U11gZOJZsnrCxXbE4SeV0qlqIiYEzkr6ZHVd8siKrCrt9/6tVovwfNaBNOocFzrKbKAu3gYfZNS60/PH38V6V8CK5pn4a2uhXcuvDfvyjU2CjYHkPjn4P3ab9BoeG/azy9+noLetO4tuXpNUMifp81MSy8qKirGfiMfyAiA2TJTVO3cyZKCkZYpC/kahIJHlQztjh3bAhj/HIDZVL3JpXE9j41tarpkzOq4TKILiotUc/UUJfrykpNz8/PyCvLd67Ltvtqk5C3bdiDEmxK2yFd7+Hvr314LiEuHLP0raJ5JrqCgRiA3lWbzC4xuSP/5xCSCLGgNpNfpqE5436xf9BcPfn/962sRAHhTwjs7dkX3wmA47eKA9OEIbu0qZD0on4Humv6Z+Bn9/Yd/+FsY/Mp4647+mo3NRbJP/zhQt2m0aVt/3aaWkvcaCjc0F29XlEpZ/4vqnO2lqVuytq1L3vBmysY3CEOKkt6rzNhQl7Opq2zXUFXydEt2T8XW3tiWyY4MGNxetq429/X5gTy8bXV31enFenppxgjn9jdoY0D1ZKHxS3LfQDdxO1cGkONvTHW1PF5iwT99UepsjBAmZ3m8SAJwojNlqiftyO6YZ4BVIAc6wkih71Oi+PrqIFRGN/UgYaiappguMWDqqN7RWLqpvmhDffG6prKNrZWb+xqTZnoKpV5XZurJsk4tt8vi0hVrO35+Q+k6kj49vDwlSW5nwEbDZgL849/2ClLlx+brsWcAPNKdz3tSojsvY0Nh9lZJ7/Ls7RK8zeXJHbEU5E8Oc6Y/b3Ywt7M2obdh+77piEhplREWWK/P4ghr2YAc05c5UxGmmQ437+ir3WyiuHSC8WoG6NrKzHWnSz/6+fatGsZ8/+QgEAKKX95Z/PL+8jePDnz7+OB3T1Ycv7i39Pndxc/v7fv0zpI3T+F189TQpaO95GxH5uoNde6Ibdc/rcUFAHdVJI42ZWOH6pFqqOrBAFgQb19e0QXUhnTeONLj5T68HDVofnxp8qOLE2rA6r73T/QpMcJjXcKhYxjTunu8HwfCgBdHK/lvaPytKdrOA4EfvX4S9eCagm0DTTk6dPf0lVIVoVB+uI8omk5os4lFBPFQRKNvr/ZZgA1IZgG6nNEuJXQGCy3CuGa4zPWQCUFENGEANqYP6sJy282jA2gxpMSMzy+2n1nEXzVzt59e6kTQ/bL316epsOr5qS9KkJomPCbLqkjdWpe7g+bIXpNCSkOLQqlZk3ZpgfvSrAk1YC8HgHl+HZkslIIGjZcONKOnANg793GEhRy+arEPIm+8MlEiY8SpNC7nLo5STebI5u2oAS2pmwuTN+cnbnREgiuydtbkRgosKfQDIzEvfXFfGxT3igA41OBJvZRgz+6uPben7sJ8/cWFBtVfGKxN6NhYwbmFWiUDdQELMjoFe5pkpWiZc1+Rr9SX6XiT3v6kJvjJ+6cmbx4bP79/8ORCrwIK/XBvbS70te2uydtWlR1Fa1l6c2H0hutyElqKtsvt8zmZbs+aaktXMuBwIiQwbKpuHRu8u6obmGJg+O4HA0/OjD86Ofriyu57q4Mfnp+yvn2kT8caBk/NJ+zzhIvtb/xRH9tdZ8A2JCacpJrcM1yh5aGxdBchfc6uDflJCXkp23KTt2YTQm93c2tM0S5le97OhMLkLTV5adV5SY0lxO25E10lFw+NfHbv6LMri/QB012lNhNQPH/X5pxdCUwwSLp03JaSEbESTN/JjIIvMYtEjT0wBgBDYsAG5DTSuAk133/3Tdpj57W0RpKid96gRnYNkMaVAapFQEcXhGegkwpyZQ8nmwp5Sw/BsOORp4VUT4tjJKmNjyhIT93pPSCa8pzeT1LiFqgcbDHCOo7cwDsKXbaOKLvdQ7RByMwI+4C4+ikFygobAictigsL7AzsJBD3yvIy17sLbAd4XisJo9Q+mq6haKPA8Dkn08ijsqJ8OxV5grra8pbmGnqr1ubGjrZWR+HZpAfqa2va2lra21s74ne4L9xsam6oq6sRyqJYrwwwwEeFkcVf/upVqWknrUHXWkjk6hX27Usjg3NdRkq5ksk8rV5/U4r6LYwZLd6wWTOT3q53Eratf38Ds4vX2Z0AyOSU7cwxQhBY6Thyxi4n8rmsKPJt8+dykz2IrzSEnjAhwyw80PUS0WB4y7b18tJu8rpi+xw1L+Wk+ZfyJPw1CacVhrUzEXC5Rj1YM5JjyDwj2Xgw+kv//I+v/t3f//3fvMLTHCiu7q40G+78gUbCq8hkcXeMlHS2t0RbLcMEe96GwqTKnGjXWZK2sSpnCx2pAb1qKvuHK0/t9jfcz6qCgJbnkWkkZvJACzQXtIBeUHFosnRxMNvzeyEMTwraXdLOMFiaV04P75zs8DOXUF/4VntsY0PxO4699fJd77SUv2thJCJXLGHQPb4YuncomOiKH12cFM8u8VDcza/q2aUpx+dXpkEapqgpRXUT3gw3p5vI3Visq2GTqWS9DYn9DSm8osAwL2Xq6Kurwyy3Pr6ziGFD37gByLJOIU+OfcIweAyJJYFtFwiSZb8Voecnqgc6C5tq0mSha0qT9T+Itqo0PxO6cj/Y27a61PzBUoMhuH1NOwZbE4/FRd2gV1B3SzhjwD5F8OhwJJZ25uRiPbgFzNqWNClJJPiwXzxYfHxh9MWt3V89XBZcUL6+v/jD4wM/Pj343aP932ipvLf3u/vL3z/Y9+29xS9vz7vAGdc4vrwz/+TSmDGO6LU9xKGpKm2vcUu/jO7KlNbiXV3lqaONudRAVMd+7xT4/fzBYHMdIh+S1YG1RmE5ZyH/jFHBYAvs6t8DcCTXgjeHJthkVk/2FOpCJm6qLokmsmHAAFinJjYTvDjUQam9Irn1VLk4Nl3h4RCLlaBFIJF4JHAFsQGG8UvJ3htH+XVEMEyFELlu7YNwADhCa5gnFypgjCQ2sBHwAAbLG/8lIuoGVuXAWU+0lmzurt7ZVm7fub48ZUtZ0vaSpM1lyZsaCnbCYC1AAYNpsH0uZWC9W8JzIpRxsluJ/l7cH6Wj4aLv5MzeWsDmzdhV+FDejM2Bi908OF4cebzsbWKhuqfvJwBuzNtRG212I/RFgmWhC5I21eSntJVn/RyA4X38q2gG8/4hfPNEXivDZhyV6OcBwFeWmz88N/r45KAO3av7aNRrFaRVDaivqcBgsO4gC74fyLRv2PemtddsXYP8IkOS3RH7XBqgYC8drM8dbS7pq8vDehuKtCrtsh2vzNxSkb41lrW9KntHfUEiSbk0vg4ujhkDdTtJBy7u67DdiW9NGq8c7L13fMyvBE2f/DOIpaIn3KNEI1LzZojUKNRsC/QpqY77R/el+YeW0w593n4iSEGZ/8hUzQ2WTPQURm2HDflF6Zvzkzdpuy9I21HMWjl5K+gFwLmJWzK3bQhZ6MZi3efpXdVZqsgHJ1uufjB5/YPR5bEYvxp1NK1xVbk7s3asz9y5iYNVQVYy9HXktsHH2A8xhVFwuoiTvEhmLOAQyEQ0qYLljYEu9JWGtXYS1oJkYmCkFg11ZXgI3LVw0wKYecJwhNCup9+JRzSoQGIb+oIEv+xxdU/kHoUNez+O8Bj6CgsIYZewBsBe1JNQHRdphsnNlAAP6IueormQFccNgfKCXiGFDoBjFeWCWipw93Dewz2KbMpGwUeWBvBx+GlAXyOPYmVFoQdJrxEM7mhvHOzvHhnqc+xobw5CaIve3u7Orvau7o6eni5HNwUYbmioa25prKqqhKNgGD/GbB1DlpgeCmihraiq/DAyisXSRlVVl9c3VFdUlJSWFTpyuigpKzZWoaC4wKKmvqa2obausa66rrKlo6GuqbK2saKxtaq5tbq9o76zu7Gjq6GhsbKmrpSrRjTcN31HeVluc1OspbnKUU+RiUb6ep1cCxqr6pqy+oZYXX2lRVV1qTNlFQU1deUNjZ65VjQ1VNmC+AZ6ulva2huccZfrHUWsqoSM638LwB9dmzYn4JObs+LzuwvfPt5ves/Tq5NfPD6A7S2OV9AZgWG/lfrq6GZ5Gkx2FxMAQzVqoEfnJz6/zRT36P/z3Tnxb1+f+tNnx378cOW/fnni//3xwh8/Pfrtk+Xvnhz44fnKjx8e/sMnxwS/p3/75uw3Tw/oQSI+gsTBAxLeCLyQQQT8+/bDwy/uzX/74YqwYAX1/SdHPru3wLNCgKJP78676T2/uDkvXt7S0HwU2Ly4LpM28dW9ecMPwBW88T5tohlV2qR3VW3riCUYzR15ETenG3GoSUlDDiUwLfHNUyOPrsx8/ujgi7sRD/Y2uFZBPojo3QbZlC2FHQM2rA596cTwocXW0b5i40KN7G6MRS4TjRWpmpKnB8rPHRq8cnz41tlRcfPM8PNb85/cX358fe77F8d//OxkFJ8c54flJWwpmHL8+auzf3p56vcvVrlz+ID+IXxAwaDjy0fLzmjiYrL44OwAe+rnV8bNofJJP7s5++XdPV/fnWdcJb5zvDPP6+Dl1akXxjVen/ji1sxXd+aYTX5xf7eJTC/uzDHAAu1M7blVLAxVxGt+Ga1FKV3l9ijpIy0ZU115+mvlWgmOuIZJlirBAmBEE7WVbWbBwSFLwlnFl58Db6xbR9oiBnyiU1j4GaXOhXNYizSAlrBQA6ZW07XlW1Jkpewbbc3Tp8Tp6aBCANo0WiRgbcQXFU2nK0iFPRUMc9Pvssx23C1E/9sUwSAjC95Vgm/ihX1155frYQlqGBcoxa6stHvsGpxDPjeh4FqHFdqNo2vDBcOR/1R7FnH7RFumfEBjTlpVSnLJjs3FO94v3bWuKX+nsmgcg9NmurKWhktAgkqwrQks9KJn9lQawcTM2bchDfDRhZFHJ3ttTX4OwCi+TYmP5gPCOV4icc1B+88BuCZrW1laAvTN2vbe/w6AASd8UmCG9LTNqu9BiK6zVvUXBmvDvbzUoAx8bk/N6dnKAHUQV8BpNzUoR3LlcYmHaLvzwYxjCVuP5cFMXtmHxkolk0nYRpsyZeCDx7gdQH3h9rAXlyRPWv/btM1vepMFSRsIyKnHGyt3NpVvJSijTn+mh/787tW5BrkNveAK8Ht7C8mt9w8USJV7t0DXbmD/YM7KcD6NmP0Bjm7LEsn3luufXhi1t/AZuc0LWbTIfmSh/uB01cHZWsUU7X+dNRm1xUklmVsBcEnWLgw4cdM7qsJpCRuytm9O3bw+a+smJd7S9K3lWVsqI85Acpg41VnkP7y/emURTzLYyiC6WGNSftrWgoxdBiTkpe3UJcx5SmsNpgsyASSIFRbAVTjpLrCk1ApHwTCOCICdcQ2scgGsgljWzgBa2IxEugZUBywPyO3oUcix6+MRISs6FbLQcFdgZgGGoa/A0lzjvGNAZax3LTyV9wbRkW/YKektMY7RrtFZSih4rA5tEWynZMvBsDJ2daXGoUq1bfw1ZNfhsfPItM1EgPbAfaFvVXmJ3t8oYiWYHxDq7mru623v6mhqbakNwmD1cjAZOnCAJUk0xMW15aLDrMCAvi4oKmY+le9oDVxjVWUNjTXtHY3ADPhBPoAH0hqbqiGcYwC5pua6mvqqiuqyyppyC1FVWyHii7LyqkITjWBwa1tNW3udY1NLVXB1Zu8cqyoy9FA3UV1taW1NSQgAHGLtDPAWYNsDoS80ragsKuU9WVUSMBjEhos9TwThdaWu9PzMs6prS7wKOy1UGHWWplYkfuOtX/07BnznVJ+5dYDKBCFg/NntPcHu//rJHjXXIwv1Btf0N6arkzFX0rUSR99y6Ish+Wl+fGGcHfTX9xc0L/3f354Qf355+H/+8cp//+rE//jmpDm45v9893TfD88PQGVIDy/hCvQ1KYHtBjMsJWeq6SCf5od1/+LIh7d2c6D89P7C1yYaPV4UFp89mP/62QGeWZyTI/Osm1O6ilkoe8/evL9YnoVsueIxbUCTERFgyV3YsByyYptuS+k+2qIAwP0NSXKw9uzxScP5ctGgguM0xw87D6N86bF1DekOkjPXNIW4o6HW7KBlvy8c675+dvj6+fFzq8MDnflNtSkVxdtqSGcLdyh2AuDx7qKV2SYty3cvTt27NHnnwviHt/cCYDD8+ZOVL58dFl88Xnl+c+7Lh/u/f34Y6P7Ll2cA8O8++cBNcGuf8dXjfS/u7GEZ7ZP61IYtvrg1q0MMBpsP8dHVsaBd//rBnjX0BcBrTkOMIdklgmFWw1rFXtye/uTmpKeCwVqxlZZJyY7u5tVcM9FS3F2RgQezXODJoOoJhqERRbSio9wGOqLSSQ4N1fxQ+t3nRsnbiMUE4RXEjYwqDzetATCeKj3La8y36v/MGgM2sq25OqO3OW+ko2S8s1gJVtIb3zq7twU7BE7CL69XkYXGYkHv2plwPg7D3Q/PDpizxCoV9DKnBEVQ8D8AMGihGiMShrueCoSHzPZPFVCl0IXGUEGnQhIUScTV5EhjzRnd5Tkt+dl1WYkVssFb3ypNfK8pf7tUQV81kpfom1kYLFQJRtHiUNF4bm+MkbWPD4avHWh6dmaQGxQwhiteWvgUdhiBvHon+0cLZYbUUHTBrQGwjG5Z+iYMGABnbHlHCrooJaE8c8d/SEGrJRv1Q+rlU8v/Y8BS0NikzPOp6RgfjKXurJMMQEJMVQLdtcB99QjpGtKY683ICtgNoL+2LKfmK9l7uSl7z4VKWoIL5kxnUXzOR2l/XVZj4Ta7cBisTVmJOiKO29dl7Xg/ddsbigtRi3nhFtrMi/v7P7t58MmFefY1p+bbTu+xMxs8MAxuyzRKXV/pIhxDynljXVzWrFUhzi5UCW3K0TbuSKttJYmZTD4bdugbAbCEgcz5VBXRhpoOCzxMoKUird4k+ZydxZkikbdG8sb3AHDG1o1JG95N37y+MGmbBD71KA8s0tHG4p39DdlUdf7XMW2d7S9dnKg7tLtraapHrzyHrMzEBAGDC7PT5KLZNqnUIqx4LYQDaYANuAI5N3FZ8OnegKyKr+DWTYgrwgLWQtwAik663jOE8GyQ0jODZ1DtZhRxxA3cN9gvQ+LgnIz+hjMBdAMkw2B4HLYFa5sDewVP68mBroC+MJjaC+j+pa+XNVdkvuGuUMBGjmWk5auVtMnHUGFgLIcMfSGxhDaSjVXj1mGiUZj7a+4Cu6u420YJh4qG+gpU0hEYQ3Cp3bbW+tbWRtALhptb6lV/QwsQypueEa+E75LXlVLeJk+rBzdM0g0LYCyduxYAD/4FGLbo7GoGw3V1ZG/lpRVFZZUlFpC4kOl0aX55rLS0osBIwbJYgZGCcDeAKETEfXlrcHhm72wUMaYb4BPx5WwFfdf8rSycBKWuhKPxKAn0FwBbeBv2BPYHcHcNxb3EGgB7rPBampf+twAs/yzv9MFchQk/4Or5lcloiNDNWdhj2ABrIb7KDJZZCUa+dA3ZfbVR2pCKQRPqrdUBmV6Yxz3498/2/f7ZElMtx//x1er//PYUg+gfny6/vDvLHN8Uv09uTj86P+IlDBR6dnnsjy+Pff5gt8mA4uN7U2vxzHSd
What you have are the "round" style which IH started using in 1958 on multiple tractor models. Your tractor would have originally had the teardrop style. These are a sealed beam light. If you put in 6-volt sealed beam units, you can use them on your H.
These specific lights may have been later replacements that IH distributed through the parts system for use on tractors like yours (based on the ground wire inside the unit).
Thanks that's what I was wanting to know. I like to
keep things as close to original as possible. Guess I
will have to make a decision to try and sell these
and fine teardrop ones
