case589
New User
i was wondering why i didn't get any replies on my post yesterday.454ih 179dih wanted to know how to time this motor. can any body help me thanks.
Best to get a service manual, if I recall the injection pump drive gear has three marks as it's the same gear used on three, four, and six cylinder engines, each using a different mark. Need to check, but think the injection pump mark is to be aligned at 14 degrees BTDC on # one cylinder compression stroke.
Hi Case589, could you please give more detail on the reason for re-timing the D-179?
Was it complete engine rebuild or injection pump was removed for repair and the 3 locking bolts were loosened on the injection
pump hub drive gear?
JimB
the crank broke.i took the idler pully loose and turned the gears to line up with the number 3dot. i turned the pump gear alittle to get gears to line up.i turned motor to number 1 compression stroke.not sure if the pump would still be in time.there is a dial pin on the front of the crank.do you line the dialpin with gears.with number 1 piston up on compression stroke the three locking bolts wasn't ioosened.its just a bearing and a crank job.the pump and pump gear hasn't been loosened.iguess i just need to the best procedure to get it back together.thanks for your reply. dave
