Super A question
Pembroke
Location
Mt Washington KY
After reading about the 300 Farmall oil pressure gauge in cold weather I started thinking about my Super A. The Hyd. unit has a gauge coming out of the side of unit and connects to the gauge on the Hyd lever bracket. The oil line has been gone for a long time. It has about an inch sticking out of unit and about an inch sticking out of gauge. Is there a way to replace just the pressure line? I really don't want to replace original gauge unless I have to. All thoughts are appreciated and welcome.
The gauge with a small tube on your tractor is a TEMPERATURE ague, not an oil pressure gauge. The "capillary tube" originally contained ether.
Some guys even repair those, apparently!
Link to gauge repair info
No repair to that tube as it is filled with a gas that expands with heat to give a reading. So you need
to replace the whole assy.
That's a hyd. temp. gauge. It's junk, new one is probably a hundred bucks or so.
