Doug Kieta
The ammeter on my SA seems to have stopped working. To get to it, I will have to remove the battery, which is a royal pain. Is there a way to check some locations in the wiring on the tractor to determine if the problem is actually in the wiring and not the ammeter? It is a magneto ignition system and the engine runs just fine. The lights work but there is no movement of the ammeter when the lights are switched on/off. The ammeter is an original so it seems odd that all of a sudden it will not register a charge when it has been working perfectly until today. Any suggestions to help me sort this problem out will be most appreciated.
Thanks for the help.
