Jess in CA
Hi there, i have a Low drum cotton picker mounted on a super H tractor, the tag was hanging on by a thread for years and i should of broke it loose and stored it away, but i didnt, well now i am trying to figure out how to get the correct info for a replacement tag, the casting #'s reveal that its a 1953 model, belly is 1/28/Y, engine is (G-164) 1/16/Y, the rear housing shows 4/18/X, maybe it was changed out somewhere in the past,the enging sr# is 1554. and the #'s are stamped at a right angle if that means anything, o.k. the sr # tags on H tractors wouldnt reveal if there a picker or regular tractor so the big question is how would the tag need to be set up to be correct?? and which tag would be used, Thanks, Jess
