F-12 oil filter base
Can anybody tell if an F14 one-piece oil
filter base will bolt on to my F12?
Mine is leaking at a crack and it looks like
the bypass spring and ball are missing and
the pressure valve is stuck/jammed.
oil base should interchange however some old style oil base can set to close to the mag. with long drive assc.
Yes it will fit, have one on my f-12 and works fine. You might have to get a different mounting gasket, I think they are different between the 12 and 14..
