carb rebuild F20
85 Bishop
New User
When replacing the gasket between the top section and the center section , the gasket is pinched under venturi ( white metal horn) How can this be removed or what is the answer ? Thanks
if you want to remove the venture I usually just take a pair of channel locks with curved jaws and spin them and they'll come out. that gasket has a good way of keeping then stuck together
