chuck kaufman
I know this has been covered before and I should have known better. My O14 carb has been giving me fi
ts .The engine would start right up only with full choke. As soon as I opened the choke she would die. I've taken this carb apart many times looking for the problem. well last week turned the advance lever to full advance.Now the carb will load up with the choke closed. I assume my timing is to far retarded. The carb will now adjust to some degree. next step is to advance the mag one notch and see what happens. Stay tuned I'll post the results. Thanks Chuck K.
