Ok I know I have aftermarket axle. Really wish since doing restoration I had a factory cast that matched tractor but oh well.
2 questions
- are there any later model factory wide front that will fit or line up correctly?
- it appears I can elongate mounting holes and slide this backwards about an inch. Might be able to then remove enough of the angle iron to match front. Any reason I shouldn't try this?
Thanks
2 questions
Thanks
