Meangreen
I have done some research on here and I want to fix the front end wobble on my M. I have lowered the pressure in one tire to give a temp fix, but now that it is winter it's time to tear things apart.
Based on what I have read the main culprit is the bearing on the vertical shaft in the front of the tractor. Is this correct?
I noticed in my parts book there is a bushing and bearing in there, could one or both be the reason for the wobble?
Thank you
Thank you
