FarmallMOwner1
New User
I've been working on getting an old Farmall M which I inherited running again. It's been out in a field for 20 years, so it needs some love.
I decided to overhaul the carburetor since I knew there had been a lot of contamination in the fuel line and since there was a slow leak out of the carburetor drain. I attempted to overhaul the carburetor once, but couldn't get the tractor to fire up after the overhaul. I then brought the carburetor to a guy I know who loves fixing up old tractors. After he overhauled the carburetor, I reinstalled it and turned the fuel back on. After about 30 seconds, fuel started pouring out of the bottom of the carburetor. I attached an image to show the exact location.
I removed the carburetor, ordered new gaskets and a new float seat, and rebuild the carburetor with those parts. I put the carb back on and had the same issue.
The float is still sealed with no fuel inside of it. I can't find any place on this carburetor to adjust the float or the float seat height other than just bending the float. Any suggestions on what I can do to stop fuel from pouring out of my carburetor?
