txdutchman
- Location
- West Texas
Finally had a chance to work on the rebuilt carb yesterday. Soaked it in B12 overnight and it must have softened and loosened whatever it was that was causing the problem. I put it on this morning and it works great now! Drove it around for about an hr to work on the next problem. I had pulled the plug on the rear end/transmission and about a half to 3/4 of a gallon of water ran out, then some very very nasty smelling thick crud. So after letting that drain out overnight earlier this week, I filled it up with diesel after getting the carb on and started driving it around. Found out 2nd gear has intermittent grinding noises and 5th gear jumps out of gear. Badly.
I reck'n we get to pull the cover off next.
Also, oil pressure on the engine is very low. Barely out of the red at high idle, in the red at idle. Checked it with gauge and it's around 10 lbs at idle 20 at high idle. I've been told they never had great oil pressure but that seems kinda low.
