1954 super h
Zack934
New User
Hey I'm new to this site and new to
hydraulics .. I'm installing a loader on my
super h stage ll and curious about plumbing
my hydraulics .. I am putting a two way
valve so I can have down pressure on my
loader . I have the reservoir under the
tank .. tell me if I'm wrong .. the two
ports on the left are live one on the Back
is live and one return ??
All of the 1/2 inch pipe thread plugs have pressure when unit lever is pulled back. 1 inch pipe plug on rear is a return port for two way hydraulics. 1/2 inch plug on back pointed to rear is the one IH used for pressure to a valve with pressure both ways. But any of the 1/2 inch ports can be used for pressure to a valve with the liftall unit operating lever locked back. Lock is located at bottom of lever.
Missed getting picture on the other post. You can see it's tight to mount a valve where IH did. If using the return oil to port on rear, a fitting to angle will be needed. Fittings on bottom of this type valve are for return oil. Using the original front suction and pressure lines the only other place for a return hose with a double acting valve is to the fill port. Other return works better though.
