Farmall A Lift-All Pressure Valve
I am looking for a pressure valve for a 1946 Farmall A Lift-All system. Would anyone know where there is one available for purchase? I believe that is the only part I am missing at this point.
Thank you,
Robert Thompson
Well, let's see. I have:
1. The lift-all cylinder (choice of two actually - both a vertical and horizontal setup),
2. The complete control valve housing (with a rubber hose attached which goes around the side to the cylinder,
3. The control rod and automatic pressure release (15200ECX according to my parts manual),
4. The small rock shaft assembly (minus the control valve rod),
So if my reading of the manual and drawings are right, I need the entire pressure valve assembly with the valve rod and valve pipe and the control valve rod mentioned in 4. above.
I'm not sure if the cylinder gaskets and cup would be any good. Can replacements be found/made still? Also, if I needed to rebuild the control valve housing, is it hard to find replacement seals, gaskets and disc/seats?
Thank you.
Happy Thanksgiving!
THe cycls are all the same just mount in different places and ways depending on attachment. They cycls
are easy to rebuild with new leather. The check valve assy by the filter can also be refreshd with new
rubber washer and general cleaning. So you need the pressure valve that goes on the manifold the linkage
going to the rock shaft under the gas tank.
Yes, those are the only things I think I need. If you have any available to sell, I'd definitely be interested.
My parts manual shows a hard pipe coming from the pressure valve (part number and 15210 E). Would you have that as part of the pressure valve?
Thank you
I use three pieces and two 90s easier to install. I have made them one piece but its hard to get the
bends correct but it can be done found out imported pipe doesent like to be bent. There is a guy on the
discussion forum other site has one for sale see if you can deal with him that way you would have some
extra parts if needed give him a try and we will go from there.
I have been unable to find anyone on another discussion forum who is selling parts for this. Can you point me in the right direction? Also, did you mean that he had the pipe, or all the other items I am missing?
Any help you could provide would be appreciated. Again, if you have any of these parts to spare, I would definitely be interested in purchasing them.
Thank you.
