for dgoodman2 m 3pt pics
glennster
heres a few pics you requested of the 3pt on my farmall m showing the stabilizer bars, the hydraulic hook up and the char lynn valve that controls the hitch. this m uses the belly pump for hydraulics. i have a live pump for it, but havent got round to puttin it on!!
Thank you much. That explains a lot. I have a lift but no draw bar and I thought the mounted in same place. I see your drawbar mounts to the same channel as your lift is on. I can run with that.
