I have a Farmall 826D that I am restoring,so I have it partially disasemble.I have the injectors out to be checked,so thought it would be a good time to check the valve
setting.I have the starter out so I was rotating the fly wheel with a screw driver ccw looking from the back.I rotated it about 180 degrees and it stopped,so I started
turning it in the opposite direction and and it turned almost 360 degrees and stopped.It's not a hard stop there is a little give to it.It's a gear drive,could it be the
trans.or the TA? I last ran it about a year ago and it ran fine.I drained all the Hi-Tran out this summer,will buy new this spring.
Thanks for any reply.
