faroutliving
New User
The 300U is finally running, and the next problem is the dump cylinders on the Davis 102E are missing. Well, I have the parts of one but the other is flat gone. Previous owner was going to get it fixed but some shop told him it was not repairable and just get a new set. The dump hoses have been bypassed and the lift works like a dream, so I'm hopeful...
A 102 manual I found online seems pretty close but the listed hydraulic hoses for the list cylinders are not like the (half rotted) ones I have. It seems the same in the drawings so maybe it is and the hoses I have are replacements that are longer than necessary?
Anyway, where is a good place to purchase replacement cylinders? The manual claims (which I can't find the reference now) 2 1/2" piston with 15 3/8 travel or some such. Pins are 3/4". Locally I can get bolt together 2 1/2" with 16" throw and 1" pins. I don't know if the extra length will make a lot of difference, nor do I know if the bolt together kind are ok for this purpose. Not even sure it will fit against the arm because of the increase in diameter.
I also would appreciate a good source for appropriate hoses? Seems like everyone around here sells hoses, so if a hose is a hose is a hose then I'm golden Sorry for what may seem like a simple question, but this is new to me. How do I judge the condition of a hose? Just replacement as they burst or is it worth buying a set? The hoses to the 3pt are all relatively new, but all but one to the loader you could convince me they are original (not that I can really tell, they just have been oversprayed with several colors of paint and have dry rot and a few flaps of loose skin).
Thanks for the help,
Deron
Deron
