My dad gas a GAS engine 444, I don't know the year or serial number.
I need to help him work on it this weekend. The loader hydraulics do not work, the power steering does not work, and he can't get it out of reverse.
The oil is very milky since he bought it ~10 years ago no matter how many times we change out the oil. I don't get it... No way it can be condensation continually building up, it's puzzling.
The transmission holds I believe 8 gallons of oil, but when we stick something in the fill plug to measure how much oil is in it, we only see about 1/4" on the end of the stick. He has no idea where all the trans fluid went. I have read that the FEL can steal oil from the trans housing to use for its operation, is this correct? I can't imagine it uses the 3 gallons from the 3pt lift...
The only thing that works is the 3 point lift.
I'm used to working on Fords, so will likely have a lot of questions in this thread that hopefully you guys can help me out with.
First question is, I am trying to identify exactly what tractor he has. It says 444 on the hood, but is has squared off fenders like a 2444. It's painted white/red and looks like it was never yellow.
It has what looks to be every HYD accessory known to man on the thing.
He has no manuals for it, so I don't even know how to fill the trans properly.
First thing I am going to do this weekend is try to drain out all the milky oil. Can I replace it with Traveler "Premium" HYD/Trans oil? I know it is supposed to take Hy-Tran oil, but at this stage I am not buying any expensive oil because it could take 30 gallons total to flush out all the milky stuff.
Back to the loader. Googling for pictures on the internet, the loader looks more like a Case 60 loader than anything I can find made by IH. Does that make sense?
Some have suggested it is a IH 2000 of 2050 loader, but none of those show up in the online parts manuals when I search by model. Again, the boom & sub frame look a lot like a CASE 60 FEL.
If anyone has any ideas on the continually milky oil, plz let me know.
