Ripper on super m
jsfarmall
Could a super m pull a single shank ripper
on 3pt hitch? Mine also has a fire crater
kit and 1 set of rear wheel weights.
shouldn't be a problem at all, depends upon soil I suppose though and how deep you are going. I can pull a single shank ripper on my JD430 with no problem. I pulled a 5 shank ripper with the SMTA but couldn't go real deep and had to add weights to pick it up
I'll be in silt loam and sandy loam ground. I'll pull it as deep as it will go but if the 1st pass aint deep enough I'll jsut change my angle and cross it again. Honestly I aint got enough to hardly be worth having a cub so no matter how many passes I make its not gonna be a problem. but I inherited grand dads super m so I'm gonna use it lol
(quoted from post at 18:58:18 10/27/16) Could a super m pull a single shank ripper
yes sir! I've seen it do that.
You will have no problem. If you do just make one pass half way down and then all the way down on a second pass. That's what I did with 38hp and now play with it at 53hp.
