steering wheel
Black spray-on truck bed coating, 6 or 8 layers, sand in between., don' do the spokes.
Leaves a grippy, black, permanent handsome coating. Have it on my Farmall for 5 or 10 years, perfect.
(quoted from post at 00:11:38 10/28/16) Fill the cracks in with JB Weld first and sand smooth. Otherwise they will just show through.
Like he said but a little further.....
  • *Take a wire brush or sandpaper and clean up the spokes nice.*Wash the wheel good with soap and water and use a scrub brush. *Rinse and wipe down with acetone. *Paint the spokes up nice and pretty. *Let paint dry and harden *Mask off spokes with painters tape. *Take some JB weld and fill in all of the cracks and bad places in the wheel grip. *Allow the JB weld to harden and cure. *Sand down the entire wheel grip smooth. *Use your favorite spray paint, truckbed coating, etc. *Allow to fully dry and cure. *Remove masking tape and install on tractor.
It should look really nice and last a long time! I have done a few this way and they worked out well.
HTML Edit
  • *Take a wire brush or sandpaper and clean up the spokes nice, *Wash the wheel good with soap and water and use a scrub brush, *Rinse and wipe down with acetone, *Paint the spokes up nice and pretty, *Let paint dry and harden, *Mask off spokes with painters tape, *Take some JB weld and fill in all of the cracks and bad places in the wheel grip, *Allow the JB weld to harden and cure, *Sand down the entire wheel grip smooth, *Use your favorite spray paint or truck bed coating, *Allow to fully dry and cure, *Remove masking tape and install on tractor.
(quoted from post at 00:40:53 10/28/16) HTML Edit
Nevermind. Too bad the "edit" feature doesn't work on this forum so we edit our posts when they aren't formatted correctly.
