weight of F12 H rear wheels
RandyM
I have a set of rear wheels from an F12 with casting #4916-D. Can anyone give me an approximate weight of the castings?
Also, if anyone has an approximate weight of a set of H steels with cast centers, I'd appreciate knowing that also.
I'm trying to determine what to do with them.
Thanks for your help.
Just guessing
F-12/ 14 cast rear wheel centers aprox 250# each
H steel rear wheels 250-300# each
I have had both off tractor and rolled them around by hand
Manageable but would not want to have it fall on you Heavy!
They weren't the easiest to handle. The boom pole on the back of the 230 helped, but the front end was pretty light!!
